Using Virtualdub, one of the options to check in the Thalen Deshaker filter is "Anamorphic NTSC (1.215)" as opposed to "Standard NTSC (0.912).
I've got some 16:9 DV shot with a Sony Digital8 Handycam. How do I know if it's anamorphic? I tried processing a file with both options, doesn't seem to make a difference. They both play as 16:9 in Windows Media Player, both look the same as far as I can tell.
Thanks for all input.
VirtualDub's default behavior is to ignore AR flags and display the frame pixel-for-pixel (720x480 square pixels resulting in a 3:2 display aspect ratio). This is important in a filtering program because you need to see the pixels exactly as they are, not a resized version of them. Otherwise you wouldn't be able to tell what is in the actual video vs what artifacts were introduced by resizing. Here's an example:
On the top is a portion of the Belle Nuit test image shown pixel-for-pixel. You can see that the vertical lines are 1, 2, or 3 pixels wide. On the bottom is the same test image show resized for a 16:9 DAR. Note how the thickness of the lines is distorted. If you only saw the bottom part of the image you wouldn't be able to tell what the source really looked like.
For 16:9 material in a 720x480 frame you have two possibilities: an "anamorphic" 16:9 DAR frame, or a 16:9 video letterboxed into a 4:3 DAR frame. In the former you will see the 16:9 video takes up the entire 720x480 frame. In the latter you will see letterbox bars at the top and bottom of the 720x480 frame.
Anamorphic 16:9 (half size, 360x240):
Letterboxed 4:3:
Okay, it would appear mine is anamorphic. So when using the Thalen Deshaker, what's the difference in checking Anamorphic NTSC 1.215 as opposed to standard NTSC .912? I've processed 16:9 video using standard numerous times because I wasn't aware of the anamorphic issue, and the processed video looks fine when rendered as a DVD.
Square pixels, NTSC .912, Anamorphic 1.215 when processing in Virtualdub?
By brassplyer in forum EditingReplies: 3Last Post: 21st Jan 2011, 06:24 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 15:46 -
x264 video file to ntsc dvd....
By halsboss in forum Video ConversionReplies: 5Last Post: 17th Dec 2007, 23:48 -
Converting a 72 min NTSC DVD to video file under 500 MB (URGENT!)
By Salva Veritate in forum Video ConversionReplies: 14Last Post: 6th Jun 2007, 14:21
