VideoHelp.com Forum
    Hi,
    i have a problem with my Samsung Home-Theater HT-Q20. The Player does not play recorded Dvd's (+r and -R). Play is prohibited. I found a firmware -update but the system does not recognize the file. The name of my actual firmware is"PDAANLSX.ROM". i did not find an actual firmware which has got the same filename.
    The is an update-file on the samsung site but it is not possible to install it, neither by using a cd-r nor an usb-stick.
    can someone help me?
    greeting from germany
  2. Member hech54's Avatar
    Das ist eine alte Samsung. Vielleicht ist es einfach tot/kaput?
    the system works fine....it just does not work with the update...
  4. Member hech54's Avatar
    Did it ever play home-made DVDs?
    it only play homemade dvds recoded by nero. just copied dvd's aren't able to play. the system syas "play prohibited"
    there is no firmware update that works with my system.
    can you help?
    greetings
  6. Member [_chef_]'s Avatar
    Ask Samsung support and your have posted in the wrong forum..........
    http://www.samsung.com/he/support/pr...theatreset.sec
    *** Now that you have read me, do some other things. ***
  1. Replies: 8
    Last Post: 5th Mar 2011, 18:00
  2. Samsung R155 DVD Recorder - "Recorded" or "Blank"?
    By mhamini in forum DVD & Blu-ray Recorders
    Last Post: 6th Feb 2010, 19:01
  3. Play Prohibited with Samsung HT-TQ85
    By Chaotik in forum DVD & Blu-ray Players
    Last Post: 11th Dec 2008, 14:54
  4. "Playback prohibited by area limitations"
    By zork152 in forum DVD & Blu-ray Players
    Last Post: 21st Jan 2008, 02:43
  5. Sudden "Playback prohibited by area limitations." problem
    By ph1losophe in forum Authoring (DVD)
    Last Post: 16th Jul 2007, 22:46
