Dear all,
I am using Xilisoft Video Converter Ultimate and I have problem with GREEK SUBTITLES. GREEK SUBS are not readable and look like arabic.....![]()
I usually convert my movies to .AVI Format.
I tried every Greek font, Arial Greek , Hellas Arial, Hellas Times, Georgia Greek, Avant Greek but NOTHING!
The problem happens ONLY with the Greek subs (.srt files, etc....) instead of the english subs which are ok.
Please have a look the sample attached file and help!
Thanks![]()
[/img]
Thread: Problem with GREEK SUBTITLES
Subtitle problems like yours are caused by 2 possible things that I can think of.
1) The program itself does not understand the character set of the language you want.
2) The operating system does not understand the character set of the language you want.
I don't use Xilisoft and I don't know why you want to use it, but since the screen capture shows the program running in English, I'd guess that #1 is probably the reason. You can try to go to Control Panel -> Regional and Language Options -> Advanced and where it says "Select a language to match the language version of the non-Unicode programs you want to use"
you can select Greek. Reboot and if you are lucky, Xilisoft will now work with Greek subtitles. Note that most subtitle programs don't understand Unicode, so Unicode usually will not work as a subtitle choice.
I believe is the #1! because WinAVI Video Converter WORKS but I do not like this program because the subs are not clear and vivid.
Could you suggest me other programs which understand Unicode?
I'm sorry, but I don't work with subtitles much and I don't remember which ones understand Unicode. Perhaps someone else can answer that.
Greek subtitles problem
By MultiNikos in forum SubtitleReplies: 30Last Post: 30th Apr 2012, 15:32 -
unreadable greek subtitles
By ioakim in forum SubtitleReplies: 8Last Post: 12th Mar 2012, 07:45 -
greek subtitles do not show at all!!
By eleeeni in forum ffmpegX general discussionReplies: 6Last Post: 27th Jul 2011, 14:09 -
greek subtitles problem
By ioakim in forum Video ConversionReplies: 1Last Post: 15th Aug 2010, 04:31 -
GREEK sUBTITLES HELP.
By AndreasTorous in forum ffmpegX general discussionReplies: 1Last Post: 10th May 2007, 11:07
Statistics
Newest guides
Latest tool updates
New media comments
