My Panasonic AG-1970's front panel doesn't work. After two years of little use, it refuses to activate the functions of it's front panel, manually or by the remote, which is a universal type one. If a tape is inserted it powers up and plays it all right but can't stop, rewind, record or eject it or power up or down via the panel. The only way to stop it is by disconnecting the power cord and waiting about an hour and then try to activate the eject button while powering up. Sometimes it works after several tries. The LEDs work fine. Any help will be highly appreciated.
If you know what you are doing, unplug the unit and open it look and see if a few of the capicitors are browning, or poped (looking not so cynildrical), meanwhile check the fuses. Other known causes the remote could be continually emmiting a signal, one of the buttons on the pannel could be jammed (locked), or the TV/VCR button could be a broken state.
If this is a swing down type of front panel like the ag-1980, my money is on the ribbon cable which connects the front panel to the main chassis.
Thanks to both of you. Will try all and let you know. Happy New Year!
S3000AH Front Panel Installation Help
By ALS in forum ComputerReplies: 3Last Post: 21st Jan 2011, 18:32 -
Looking for a 3.5" Front Panel to Control VMC
By eist1 in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th Nov 2008, 13:45 -
Panasonic AG-1970
By BryanG in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2008, 17:52 -
Front panel audio gone quiet all of a sudden
By specane in forum AudioReplies: 8Last Post: 5th Aug 2008, 10:02 -
panasonic dmr-es46v doesn't work
By Delreek in forum DVD & Blu-ray RecordersReplies: 7Last Post: 28th Sep 2007, 05:25
Statistics
Newest guides
Latest tool updates
New media comments
