VideoHelp.com Forum
    Hello-
    Am trying to put some .tp files onto regular 4.7DVD (SD).
    Downloaded HDTV2DVD 0.4 (Free) and installed on Vista Home Premium SP2.
    Installer complained about not having .NET 1.1 so I let it take me to MS page and installed .NET1.1
    Installed to C:\HDTV2DVD (not Program Files) ran as administrator and still get this error after dragging file into layout area and double clicking the icon of the file I just dragged over.
    Any thoughts?
    Thanks-Cathy
    An unhandled exception has occurred in your application.....Exception from HRESULT: 0x80040265
    Details of error below
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.Runtime.InteropServices.COMException (0x80040265): Exception from HRESULT: 0x80040265.
    at QuartzTypeLib.FilgraphManagerClass.RenderFile(Stri ng strFilename)
    at x14ee85f5d732c07f.x79ed6fa5f8db6479.x535825f93c028 407(String xa39af5a82860a9a3)
    at x14ee85f5d732c07f.xb6dca8349e33d934.x8ab0d03b11b82 1b8(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
    at DevComponents.DotNetBar.SideBar.C6(BaseItem 41V)
    at DevComponents.DotNetBar.BaseItem.RaiseClick()
    at DevComponents.DotNetBar.BaseItem.InternalMouseUp(M ouseEventArgs objArg)
    at DevComponents.DotNetBar.PopupItem.InternalMouseUp( MouseEventArgs objArg)
    at DevComponents.DotNetBar.ButtonItem.InternalMouseUp (MouseEventArgs objArg)
    at DevComponents.DotNetBar.SideBarPanelItem.InternalM ouseUp(MouseEventArgs objArg)
    at DevComponents.DotNetBar.SideBar.OnMouseUp(MouseEve ntArgs e)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at DevComponents.DotNetBar.SideBar.WndProc(Message& m)
    at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
    at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 1.0.5000.0
    Win32 Version: 1.1.4322.2032
    CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
    HDTV2DVD
    Assembly Version: 0.4.2132.24074
    Win32 Version: 0.4.2132.24074
    CodeBase: file:///C:/HDTV2DVD/HDTV2DVD.exe
    CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
    System
    CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
    System.Drawing
    CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
    Assembly Version: 5.2.0.0
    Win32 Version: 5.2.0.5
    CodeBase: file:///C:/HDTV2DVD/DevComponents.DotNetBar.DLL
    System.Xml
    CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
    System.Design
    CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
    Accessibility
    Win32 Version: 1.1.4322.573
    CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
    S2DProgressBar
    Assembly Version: 1.0.2109.17800
    Win32 Version: 1.0.2109.17800
    CodeBase: file:///C:/HDTV2DVD/S2DProgressBar.DLL
    Interop.QuartzTypeLib
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/HDTV2DVD/Interop.QuartzTypeLib.DLL
    Interop.DexterLib
    CodeBase: file:///C:/HDTV2DVD/Interop.DexterLib.DLL
    ************** JIT Debugging **************
    To enable just in time (JIT) debugging, the config file for this
    application or machine (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the machine
    rather than being handled by this dialog.
    Can you post the details from ts/tp files? Use mediainfo, open video, view->text and copy and then paste the info here.
    Or try another free dvd converter like avstodvd, dvdflick, favc, etc.
    Thank you Baldrick--
    Here is the video info from MediaInfo... I will check out avstodvd, etc.
    General
    Complete name : C:\HDTV2DVD\The National Parks_ America's Best Idea-(The Scripture of Nature (1851-1890))-2009-09-27-0.tp
    Format : MPEG-TS
    File size : 5.49 GiB
    Duration : 2h 3mn
    Overall bit rate : 6 348 Kbps
    Video
    Menu ID : 1 (0x1)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Duration : 2h 3mn
    Bit rate mode : Constant
    Bit rate : 5 523 Kbps
    Nominal bit rate : 10.4 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate : 59.940 fps
    Standard : Component
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.100
    Stream size : 4.78 GiB (87%)
    Audio #1
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Duration : 2h 3mn
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Channel positions : L R
    Sampling rate : 48.0 KHz
    Video delay : -209ms
    Stream size : 170 MiB (3%)
    Audio #2
    Menu ID : 1 (0x1)
    Format : AC-3
    Duration : 2h 3mn
    Bit rate : 192 Kbps
    Video delay : -215ms
  1. HDTV2DVD does not load up TS-file
    By feilofix in forum Authoring (DVD)
    Last Post: 12th Nov 2008, 13:25
  2. New Tool: HDTV2DVD
    By ChrissyBoy in forum SVCD2DVD & VOB2MPG
    Last Post: 2nd Jul 2008, 22:05
  3. HDTV2DVD - .TS wont load
    By NotSoEasy in forum SVCD2DVD & VOB2MPG
    Last Post: 15th Mar 2008, 19:09
  4. How to load .ts file into HDTV2DVD?
    By JR.S in forum Newbie / General discussions
    Last Post: 15th Nov 2007, 01:59
  5. Replies: 18
    Last Post: 27th Oct 2007, 12:01
