VideoHelp.com Forum
    I have no idea how to go about this. I have an MKV file with hard-coded subs that I want to remove.
    When opening the original file in VLC, I had the option to disable the subs, but when I re-encoded the file to make it smaller, I could no longer disable the subs. I re-encoded it with MeGUI.
    Remove the subtitles before you convert. Use mkvtoolnix.
    I figured it out myself, actually. Thanks for the help.
  1. Removing 'soft-coded' subtitles for burning...
    By twopups in forum Subtitle
    Last Post: 6th Apr 2012, 17:04
  2. TNT .TS file Extract hard coded subtitles
    By JeanPaulo in forum Subtitle
    Last Post: 15th Feb 2012, 23:27
  3. bdrebuilder no hard coded subs
    By **Bud** in forum Blu-ray Ripping
    Last Post: 5th Jan 2011, 09:48
  4. Hard Coded Subtitles - Remove / Hide?
    By jlrm365 in forum Subtitle
    Last Post: 3rd May 2010, 21:59
  5. Replies: 4
    Last Post: 16th Jan 2008, 06:12
