HiI am so stuck my AVStoDVD has been working fine, and the other day i tried to burn a File onto DVD and it had an error close to end of burning, i tried another file did the same thing, also when i try to put the preview up of the file it takes a while to come up and when it does there is audio but no picture, I unistalled it cleaned the registry and installed 2.2.5 couse i had 2.2.4 it still didnt function properly, i looked on problem reports log, I copied and pasted it this log is from when i try to preview the file and it's not responding Please can anyone help
A problem caused this program to stop interacting with Windows.
Problem signature
Problem Event Name: AppHangB1
Application Name: AVStoDVD.exe
Application Version: 2.2.0.4
Application Timestamp: 4afeb042
Hang Signature: 9b60
0
OS Version: 6.0.6002.2.2.0.768.3
nature 4: 9b60
Additional Hang Signature 5: b6c08eb3456f5ff00afc4138d6c7248f
Additional Hang Signature 6: 9b0e
Additional Hang Signature 7: 5f75ea9f5cf2bf5497a302c7bb8ae3ac
Extra information about the problem
Bucket ID: 894622151
this was the other log that i found
Problem signature
Problem Event Name: BEX
Application Name: AVIMux_GUI.exe
Application Version: 0.0.0.0
Application Timestamp: 48c27d83
Fault Module Name: AVIMux_GUI.exe
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 48c27d83
Exception Offset: 000cad96
Exception Code: c000000d
Exception Data: 00000000
Locale ID: 1033
Additional Information 1: 2bbb
Additional Information 2: d0d1d2bd0f106715605daedc7284fdd7
Additional Information 3: 37fa
Additional Information 4: a4c091a89184e60cc0e886be211a1256
Bucket ID: 342051171
Thread: AVStoDVD 2.2.5 not working
Hi ghosthunter38,
it is quite difficult to diagnose what's going on, mainly because the issue seems to be related to the burning step and not directly to AVStoDVD. But I can provide some "general" hints:
1. avoid hundreds of video/audio codecs (ffdshow is usually enough)
2. have a clean registry
3. do not exceed with TSR sw
4. uninstall AVStoDVD and make sure that HKLM/SOFTWARE/AVStoDVD registry key has been removed (it should)
5. be sure that you have correctly installed AviSynth and ffdshow
Let me know
MrC
AVStoDVD 2.4.0
By Hoser Rob in forum Authoring (DVD)Replies: 0Last Post: 30th May 2011, 20:37 -
AVStoDVD stops working after encoding video
By tperkins13 in forum Authoring (DVD)Replies: 1Last Post: 19th Apr 2011, 07:10 -
AVStoDVD
By Dooker in forum Authoring (DVD)Replies: 10Last Post: 24th Aug 2009, 07:29 -
AVStoDVD but than VCD
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2009, 16:30 -
AVStoDVD!
By Milardo in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2009, 05:01
Statistics
Newest guides
Latest tool updates
New media comments
I am so stuck my
