Hey everyone,
I was recently given a 2 year old HP Pavilion desktop PC, model a6220n. I want to use it as a HTPC with my HDTV and surround sound system. However, since it is an older computer, I am worried that it won't play all the newer HD formats smoothly. If that is the case, I would like to use it as a server for music and videos.
Is this computer's hardware and software strong enough to play HD formats like AVCHD, blu-ray discs, xvid, hdv, etc (anything current/near future)?
Specs for HP a6220n:
Intel Core 2 Duo E4500
2 GB ddr2 ram
400 gb hdd
Intel GMA x3100 graphics
here's a link from HP site:
http://h10010.www1.hp.com/wwpc/ca/en...-81048791.html
Thanks for the help!
P.S. - If you think some components are too weak, please provide a cost-effective replacement.
You probably need a better graphics card. The CPU should be enough for 1080p.
thanks, Baldrick!
would someone recommend a gpu? possibly fanless?
I know it really boils down to whether I'll be gaming or not.... so, lets say possibly... Haha.
Yes, I might game, but I don't care too much about graphics in games, just playability. The HDTV is 1080p resolution, FYI.
Thanks again!
Here's a few suggestions for a low end video card that can playback 1080p:
http://www.newegg.com/Product/Produc...82E16814102829
I've used this Gigabyte ATI HD 4350 on a few builds. I use one on my Q9550 system and it does well with 1080p. I don't game so I can't give you any opinion on that.
http://www.newegg.com/Product/Produc...82E16814125251
http://www.newegg.com/Product/Produc...82E16814150335
thanks, budz.
What is needed to get video AND audio to go to the TV over HDMI? does it connect to my mobo's onboard sound or do I need a special sound card?
thanks!
HDCP on a HTPC does not work.
By _punished_soul in forum DVD & Blu-ray WritersReplies: 3Last Post: 20th Dec 2009, 11:55 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:45 -
BUILDING HTPC To work with Hauppauge MediaMVP
By THE_oldguy in forum Media Center PC / MediaCentersReplies: 23Last Post: 29th Sep 2007, 23:25 -
Will PATA work with my pc. Hp pavilion 7955?
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 26th May 2006, 20:58 -
Using Server 2003 for Video Work
By laseats in forum Newbie / General discussionsReplies: 3Last Post: 13th Mar 2005, 00:57
