VideoHelp.com Forum
  1. I've been searching for ages for something to cut an .AVI file in half. Based on either the keyframe or the filesize/length whatever.
    Only thing mandatory is that it has to be able to run from commandline. I couldn't figure it out using nandub/vdubmod. I can only split it with them if I know the total keyframes. But I want to split it automatically.
    Anyone know of any tool that will do this?
    "Against All Odds"
    I would try ffmpeg or avidemux. Just google for cutting examples.
  3. ffmpeg has a good one but unfortunately it doesn't cut avi's. avidemux seems to have an option too but it didn't work for me. I made a thread about that here and in avidemux's own forum.
    Any other suggestions are welcome. No luck so far
    "Against All Odds"
  1. CrossPlatform command line tool to multiplex avi files?
    By Selur in forum Newbie / General discussions
    Last Post: 23rd Mar 2012, 15:29
  2. Command line tool to demultiplex video
    By lovyagin in forum Editing
    Last Post: 20th Dec 2009, 12:43
  3. Command line tool to take AVI samples
    By Dean C in forum Editing
    Last Post: 9th Sep 2008, 05:55
  4. Command line text overlay tool
    By lmundy in forum Linux
    Last Post: 13th Jul 2008, 13:58
  5. Command-Line Tool to Join Videos?
    By RobDude in forum Editing
    Last Post: 4th Jul 2007, 12:53
