Is there a way(maybe a program) to recognise whether a DVD is untouched or shrinked? I'm talking if you do not know what the source has been before backup
Results 1 to 11 of 11
If it's more than 2 hours on a DVD 5 chances are pretty good it was shrunk. Otherwise, I don't believe there's any kind of tag that you could get that info from.
If you use ifoedit and open the video_ts.ifo file from the dvd with it, in the top window pane click on the vmgm_mat line and in the bottom window pane you will see a line at the top called "VMG indetifier", look to the right of this and you will see a name. Dvd shhink (and some other similar apps) unless changed by the user will add in their program name to this line instead.
So for example it might say VGM Identifier..........dvdshrink 2.03
other then that your other options are to find someone with the original who can tell you the discs size or if it suffers from very bad compression with a lot of block noise that is usually another tell tale sign
but there is also the chance that DVD Shrink was used to make untouched backup....thanks anyway for your fast and detailed reply
Is there anyone else that can suggest something up?
If the movie or etc. was only shrunk 10 or 15 % so that it would fit on a DVD-5, any change to PQ might not be apparent. It's not like that split-disk business with Fab, where the program insists on inserting that annoying graphic of their crown-wearing monkey logo. (I'd love to know how to suppress that, without resorting to PGCedit or VOBblanker.)Originally Posted by ppeterrWhen in Las Vegas, don't miss the Pinball Hall of Fame Museum ( http://www.pinballmuseum.org/ ) (http://lasvegas.wikia.com/wiki/Las_V...of_Fame_Museum ) -- over 150 tables from 6+ decades of this gradually disappearing American art form.
Are we talking homemade or store-bought?
If it's on a SL DVDR then it has been decrypted and most likely shrunk, if it's on a DL DVDR then it has been decrypted and most likely untouched.
duh,everyone knows that :POriginally Posted by MOVIEGEEK
I'm talking about cases in which you do not know what the source has been...I guess the only reliable way is to ask another guy that has got the same discs to tell you the right size...
duh,if you have a copy of a movie and dont know the source then.....
Ben Johnson-I didnt take any stereos!
...you need to go to a store and buy it,duh.
I did have one sold to me that was on -R media - pretty good work for a copy. I sent the guy an email detailing what he'd used to create the disc, etc; including software used and all that. Got a refund.
Except for the fact that DVD-R media has a purple bottom, many here could likely produce a convincing copy of most DVDs if prompted. Why bother?
If you're only watching the thing, and it plays okay - who cares?;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Because its against forum rules to talk about illegally obtained copies of movies that you dont own.
Authoring An Untouched Blu-Ray Movie File.
By mamasta in forum Authoring (Blu-ray)Replies: 0Last Post: 4th Dec 2010, 21:02 -
LG RH2T80 - won't recognise DVD's
By Dalene in forum DVD & Blu-ray RecordersReplies: 3Last Post: 16th Oct 2010, 23:34 -
Untouched Menu
By zetallico in forum Authoring (Blu-ray)Replies: 7Last Post: 15th May 2010, 19:10 -
DVDFab won't recognise DVD
By audax in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2010, 00:16 -
Merge several avi:s untouched ?
By offer in forum Newbie / General discussionsReplies: 4Last Post: 27th Jul 2008, 14:19
