What programs & settings do you use to get the best quality out of video to play on archos 605
Thread: Archos 605 Video Encoding
Looks like it supports Xvid and Divx encoded AVI files. AutoGK is very good if you just want to set it and forget it. You'll be transcoding video in 5 minutes of opening the program for the first time. Xvid4PSP is "better", but you need to know what you're doing. As far as quality is concerned, it looks like 640x480 for 4:3 source files and 720x400 for 16:9 would be good resolutions. Bit rate depends on the source material. 2 pass transcoding will give you a good balance of video quality and small file size.
You must make sure your final video file doesn't exceed 2GB in size."Quality is cool, but don't forget... Content is King!"
I am using Xmedia Recode to convert videos I have converted about 15 videos 2 played full screen & these rest about 20% to 25% less than full screen how do I get these video to do full screen without setting the player at full screen. Here are the settings I am using Xvid 720x576 pal 16:9 zome none what settings do I need to get them to play full with Xmedia Record
Try 856x480 1:1 A/R and see if the player compensates for the slightly larger dimensions.
I get error can not play video image size to big with the settings you said to try Soopafresh
[Archos 605] transform from 720p.HD.DVDRip.XviD.AC3 to Archos format ?
By birdwing in forum Portable VideoReplies: 2Last Post: 5th Nov 2009, 23:41 -
Archos 605 Wifi Video Help H.264
By BladedDragon in forum Video ConversionReplies: 5Last Post: 16th Sep 2008, 08:14 -
Archos 605 Audio-Video Synchronization Issues
By analein in forum Portable VideoReplies: 5Last Post: 31st Aug 2008, 13:27 -
help with my archos 605
By mustang1967 in forum Video ConversionReplies: 4Last Post: 27th May 2008, 21:43 -
testing surfing on my archos 605
By Baldrick in forum TestReplies: 0Last Post: 31st Mar 2008, 11:50
