VideoHelp.com Forum
    Can anybody give me some advice how to do %subject% ?
    I have some L5.1 movies but I need them in L4.1. I have some practise with matroska manipulation, but not with reencoding.
    Thanks a lot for any advice
  2. Member Soopafresh's Avatar
    H264info will change the AVC level without re-encoding. It only works on raw h264 files so you'll have to use Yamb to demux your video. You can also use Yamb to remux it.
    "Quality is cool, but don't forget... Content is King!"
  3. I'm a Poll Super Moderator johns0's Avatar
    You can also use tsmuxergui and change to 4.1 without re-encoding and demux to raw h264 and ac3/dts at the same time,then use mkvmerge to mux again.
    If your project only requires ts or m2ts files then no need to demux and remux,tsmuxer will output to ts and m2ts and avchd/blu-ray folders as well.
    Ben Johnson-I didnt take any stereos!
  1. Change avc level and reference frame
    By cote112 in forum Video Conversion
    Last Post: 24th Mar 2011, 10:45
  2. Autoguessing of AVC level
    By tom.tlr in forum Video Conversion
    Last Post: 14th Dec 2010, 13:25
  3. convert .mkv from level @5.1 to level @4.1
    By florinus in forum Newbie / General discussions
    Last Post: 29th Nov 2010, 15:33
  4. Level Of MPEG in Conversion Process
    By dbborders in forum SVCD2DVD & VOB2MPG
    Last Post: 21st Sep 2009, 10:55
  5. Encoding matroska file to AVC level 3
    By flash74 in forum ffmpegX general discussion
    Last Post: 11th Feb 2008, 11:04
