I'm trying to burn a 8.5 GB double layer dvd with the Burn software, but it keeps giving me a disc drive error which doesn't occur with my 4.7 GB discs. Does anybody know the problem or if this is possible? Are there any other freeware somebody can recommend? (It seems all of the guides say to use toast, but I don't have 80 dollars to blow...) Thanks
Thread: Burn software issues
Is it snow leopard you have? I have the same issue, can not burn dual layer dvd's even using toast. It all worked ok until i upgraded to Snow Leopard.
There are quite a few people with this issue.
Yes I have Snow Leopard, so that just must be the issue. Thanks for the help, hopefully somebody fixes this soon.
Not freeware but donationware: LiquidCD http://www.maconnect.ch/index.phpOriginally Posted by RedGiant947
I only use it to burn…
bye and Happy ChristmasSome drawings ? http://www.whynotflores.com/. A software for DV, DVD-Video, HD files (AVCHD/…): http://www.movieconverter-studio.com/ 1.6 (2010/08)
under Snow Leopard, liquid CD does not work with dual layer either
I'm having issues with some of my backup software
By tinpanalley in forum DVD & Blu-ray WritersReplies: 34Last Post: 8th Feb 2009, 08:16 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46 -
Burn Issues Help!!!!!!
By radikal in forum Newbie / General discussionsReplies: 2Last Post: 9th Feb 2007, 19:11 -
Lifeview Software ISsues
By XCiT3 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Feb 2007, 00:37 -
DL issues with standalone player or burn software?
By SKiNFreak in forum DVD RippingReplies: 10Last Post: 19th Dec 2004, 19:30
