VideoHelp.com Forum
  1. Member mew1033's Avatar
    I recently went through an adventure converting an HD .mkv video file to a DVD+R DL. The resulting DVD's audio doesn't work in most DVD players. I just found out that it's because the audio track is DTS 6 channel. Obviously, that's not going to work in anything that doesn't have the hardware to play it.
    I used AVStodvd, and I still have the source and project file.
    How would I go about extracting the audio, downsampleing (is that the right word) it to a simple stereo feed, and re embedding it in the DVD. I don't need to keep the original 6 channel audio. In fact, I'd rather not so that I can save space.
    Another option I have is to just open up the AVStodvd project file and tell it to convert the audio to ...... WAV? MP2? I'm not sure... When I do that, I get a warning saying that 6 channels isn't supported by WAV or MP2 and it switches to AC3.
    If neither of those are good ways to achieve what I want, then what would be?
    Thanks!
    A little nonsense now and then is relished by the wisest men.
    -Willy Wonka-
  2. I'm a Poll Super Moderator johns0's Avatar
    Load the mkv into eac3to gui and select 448 ac3,then use mkvmerge to mux the ac3 with the mkv and uncheck the dts audio and save,then encode the new mkv,if you need to read on how to use the apps i mentioned theres dozens of threads and help guides you can search.
    Ben Johnson-I didnt take any stereos!
  1. hjelp til mkv conventerer x264.DTS to stereo sound.
    By rune m in forum Video Conversion
    Last Post: 20th Jul 2010, 07:39
  2. DTS encoding ( Stereo to surround ) ?
    By 3thman in forum Audio
    Last Post: 6th Feb 2010, 06:06
  3. How to downconvert footage from HD to SD without camcorder?
    By Canon GL-2 Guy in forum Newbie / General discussions
    Last Post: 30th Apr 2009, 09:31
  4. Convert DTS to Stereo
    By gb_direwolf in forum Audio
    Last Post: 17th Mar 2009, 07:42
  5. DTS to stereo wave ?
    By achtungpop in forum Audio
    Last Post: 3rd Dec 2007, 05:38
