Ok, first off, I have already gone through the existing guide (originally posted 5yrs ago) - and you can see my resulting posts there as well (http://forum.videohelp.com/topic234240.html).
I also tried using the last instructions suggested. Didn't work.
I'm really thinking maybe we need an updated guide? Maybe for dummies like me?
Dunno what I'm doing wrong, but I've tried 7 or 8 times now without success
To quickly re-cap, the main video is VTS_04_1-7.VOB originally, and then only 1-6 after converting WAV to AC3. I cannot seem to get it back to a working menu & chapters.
Thanks for any help![]()
Yeah, so? You replaced a big PCM WAV audio file with much smaller AC3 audio. It stands to reason that the number of VOBs might decrease. Did you test that version as a DVD to make sure that it worked, chapters, audio, and all? The chapters you get back when muxing using Muxman by going File->Import Chapters and adding in the Celltimes.txt file that PGCDemux gave you.Originally Posted by DeathStalker77
Did you follow the instructions in the guide to which I linked in your other thread? Did you do the 'Replace' step using VobBlanker?I cannot seem to get it back to a working menu & chapters.
Sorry if I seem a bit thick, but it's not quite so easy jumping back and forth & "mixing" two separate guides that were written for different purposes. Now while it may seem a simple thing to you, it's not something I'm very familiar with, so there's no need to be rude about things.
And if I could "test that version as a DVD to make sure that it worked, chapters, audio, and all?", then I'd *have* a working DVD at that point, wouldn't I?
It is actually extremely easy, i have done it many times, also to remove audio to clean it up, then replace it.
http://www.digital-digest.com/articl...ams_page1.html
You can follow the flash video and pause it as you do it the first few times to make sure you don't mess it up.Originally a member since 2001, LONG LIVE TARAN's!!!
I will give that a try! Thank you!
That appears to have done the trick!
Thank you Noahtuck!
Happy Holidaze to everyone!
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 09:15 -
Need FREE DVD Authoring Software (Which Authors VOBs & Allows Menus Etc)?
By larrytxeast in forum Authoring (DVD)Replies: 15Last Post: 26th Jul 2010, 13:07 -
join H.264 mp4 with a AC3/DTS/LPCM audio stream
By xrlem01 in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2009, 08:09 -
Dvd Vobs: change audio from LPCM to AC3 2.0
By biancolone in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 06:16
