I am trying to use my Sony HDR SR12 as a webcam instead of the built-in webcam on my Sony Vaio. Does anyone know if this can be done and how?
JIM
Results 1 to 12 of 12
I have a Panasonic HDC SD5 camcorder which has a similar (but lower) specification to yours. I use it for reading because of my bad eyesight. It feeds a monitor (or tv set) through the HDMI oullet and gives about 5x magnification. It has to be on a very rigid stand (table-clamp monitor stand not tripod) .
Try as I may, I can not get it to feed the monitor through the computer. It might be possible through a suitable captutre card. but even then the computer is not likely to be capable of treating it as a web cam without more software.
Some digital still cameras are advertised as being able to be used as webcams. I tried one that happened to available in the family. The resolution was not good enough for a reading aid. The output was 'Viewfinder' quality not 'photo' quality.
Please post here if you have any success.
Good Luck from mike
Unlike DV/HDV over IEEE-1394, AVCHC cams aren't well supported over USB for live capture or live viewing.
MiniDV/D8 cams often have a webcam mode (352x240 CIF) that works over USB.
Orange Micro has software (WebDV?) that converts 480i/576i DV over IEEE-1394 for webcam use.
Used MiniDV/DV cams are cheap on Craigslist or eBay.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Thanks. I just found out that my expensive camcorder cannot be used as a web cam. i will have to buy a different one with USB streaming for that purpose.
Thanks!
Few consumer level MPeg camcorders (other than HDV) or digital cmeras stream video over USB.
Most have SD interlace analog video outputs that can be captured.
Webcams are a different breed of product.Recommends: Kiva.org - Loans that change lives.
a nice camcorder that can usb stream with nice color and clear, what would someone recommend....don't want to have to buy the internal capture card....how about dazzle?.....layman terms please have a hard time understanding all of this..
thanks!
There is an awesome piece of software called ManyCam that might help you. It can select almost anything as a camera source... even your desktop (or you can specify a box that you've clicked and dragged on the desktop to be your source).
If your camera connects to the computer at all and shows any kid of a "live preview", you can tell ManyCam to use the "selected box" on the desktop as a source and then draw the box around your preview window.
My brother does this with an old digital still camera that has a live preview window. Best of all.. freeware!
http://www.manycam.com/Even a broken clock is right twice a day.
windows 7 is not recognizing older camcorders?
Win7 like all previous Windows versions supports live streams from webcams, TV tuners and DirectShow codecs. DirectShow supports live DV/HDV steams over IEEE-1394 among other streams.Originally Posted by template
Most video over USB (ignoring WDM tuners and webcams) is proprietary.
Consumer digital cameras and AVCHD/MPeg4 camcorders mostly don't stream live over USB. They transfer pre-recorded files. Most will output analog SD video that can be captured with an analog capture device.Recommends: Kiva.org - Loans that change lives.
usb streaming was ok on xp.. ..need driver for "sony dcr-hc38" for windows 7 64 bit...can't find it if i tried for days...thanks!
anyone have a suggestion on how to connect the sony dcr-hc38 without the cd....actually it has a cd that is only "picture motion browser version....but after installing that the camera will not even be recognized on the pc...no link to click nothing..for a driver to download?..
All DV and HDV cams stream over Firewire. Orange Micro had an app called WebDV that converted the DV stream into a webcam stream.
Many Sony D8 and MiniDV camcorders also had a low res CIF webcam feed over USB. Most messaging software recognized the Sony USB stream as a webcam.
The SD MPeg2 cams, still cams and now AVCHD cams lack this "live" mode.Recommends: Kiva.org - Loans that change lives.
are you saying to buy one that is firewire?........
is this orange still in business?
why did the sony dcr-hd38 work on xp?
i made a thread somewhere and now can' find it?....
need step by step instructions what to do please and of course many thanks!
sony hdr-sr12 new HDD camcorder is 1080p or 1080i?
By deejay.2001 in forum Camcorders (DV/HDV/AVCHD)Replies: 31Last Post: 8th May 2010, 13:04 -
Frustrated Sony HDR-SR12 Owner
By jehill in forum Newbie / General discussionsReplies: 20Last Post: 5th Jul 2009, 03:54 -
Sony HDR SR12 Questions
By Stiff in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 29th Jan 2009, 06:29 -
sony hdr sr12 output to klv32s200a via component
By tomhanks in forum Camcorders (DV/HDV/AVCHD)Replies: 0Last Post: 29th Dec 2008, 17:01 -
Download Video from Sony HDR-SR12 TO PC
By sulliven in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 19th Nov 2008, 16:34
