VideoHelp.com Forum
  1. Member dzsoul's Avatar
    I currently use RCA cable from DVD player to TV.
    There is a video setting in the setup. which is the best?
    interlace-YUV
    TV-RGB
    P-scan YPBPR
    PC-VGA
    S-video
    the default is S-video.
    if possible, can you explain each of them briefly?
    None of those will make any difference with your composite connection.
  3. Member yoda313's Avatar
    Exactly.
    In order to step up quality you will need to at least use either component or vga since you have that option. Then you will be able to get progressive output assuming the tv has the input and supports it of course).
    An s-video cable will give an improvement over composite.
  1. Setting MPC-HC as the default player in MCE
    By mx5 in forum Software Playing
    Last Post: 24th Aug 2009, 22:36
  2. setting Sony DVP-NS78HS DVD Player region-free
    By siluet in forum DVD & Blu-ray Players
    Last Post: 31st Oct 2008, 13:02
  3. media player classic standard filter, setting it up
    By THX-UltraII in forum Newbie / General discussions
    Last Post: 19th Aug 2008, 17:31
  4. Tevion TDVD08 DVD Player - Picture problem when 5.1 ch setting used
    By alfredspacey in forum DVD & Blu-ray Players
    Last Post: 1st Jun 2008, 01:03
  5. Mustek V56L-5E DVD player How To Reboot remove YUV P-Scan setting
    By ImNoSmarterN5thGrdr in forum DVD & Blu-ray Players
    Last Post: 8th Aug 2007, 08:32
