VideoHelp.com Forum
    I made 4 coasters so far and i am not doing anything different! Couple of weeks ago i had a problem with the terminator salvation shrinking and with the new BD_Rebuilder update that problem was resolved but this week, i used anydvd hd as usual to rip bourne identity and fast and furious 4 then shrunk both movies in full so i can have the menus and such burned them both with imgburn as usual both blu-rays play just fine on my computer and my laptop but when i put them in my ps3 the blue loading strip comes up then it goes away and says "invalid disc 80029209". i have the latest updates on everything! and i did searches on the internet, i just can't figure out a solution for this problem! I am sure if i go ahead and rip ONLY the movie it should work fine but i would like to have everything. Is this a new bug with the latest bd_rebuilder?
    I don't own a PS3, but if you search our forums I believe that others have posted that the PS3 never has been able to play BluRay full disc backups on DVD media. If you are not burning DVD media but burning to BluRay discs you definitely need to tell us that. If you want to search for related posts, please do so at the very top level of all the forums. Search is broken and only works at the top level. Somehow as a new member you are apparently expected to know this despite nobody (but me!) bothering to tell you that search is broken and this is the only way it works. I was a member here for years and didn't know that search was broken because I had no reason to use it for a long time. Then I bitched about it not finding anything and some other long time member pointed out that you have to do it at the very top of all the forums for it to work. It's broken within any individual forum.
    Welcome to the forums.
    thanks yes i am burning on bd-rs.
  1. My DVD backups are "invalid" in Sony Blu ray player
    By KeithMckane in forum Authoring (DVD)
    Last Post: 26th Feb 2010, 15:11
  2. HCenc "Invalid MPEG-2 Frame rate" error.
    By Maikeru-sama in forum Video Conversion
    Last Post: 8th Jul 2008, 18:09
  3. Philips DPV-5992 not recognizing a USB HD - "Input Invalid"
    By benvid in forum Newbie / General discussions
    Last Post: 21st Jun 2008, 17:02
  4. Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
    By Specialist in forum Latest Video News
    Last Post: 16th Feb 2008, 08:08
  5. Clonedvd error"invalid block start code"
    By demonwarrior in forum Newbie / General discussions
    Last Post: 6th Aug 2007, 05:01
