I have a DVD-R of a TV recording. The DVD plays on insert but has a menu (pressing the menu button produces a menu on my set-top DVD player and on Apple's DVD player). I know that I can fix this in MyDVDEdit so the menu appears on insert, but I don't know what to do. Can someone help me with this? Here is a screenshot of my current settings according to MyDVDEdit.
Don't use MyDVDEdit, but it is a User Operand flag you need to set
that will prohibit skipping the Menu and/or set the Menu to be
"First Play" upon insertion of the DVD.
Start in the Prohibited User Operations tab there ( as per your screen shot)
and see if something exists there..."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
You should have a Jump Title 1 in the First Play PGC.
First Play is the PGC executed when you insert the DVD.
You have to replace this command with Jump VMG Menu title, that's all.
Jerome
Thanks for the replies. I do not see any information listed in the First Play section. Here are the 3 screen shots:
http://img163.imageshack.us/img163/9956/picture2wc.png
http://img69.imageshack.us/img69/1800/picture4lk.png
http://img191.imageshack.us/img191/2919/picture3yz.png
That's the problem. You should have something.
I you don't, the result depends on the player.
- Some players execute VMG Menu Title
- Some ones run Title 1
- and some ones (the majority) crash.
Add the Jump VMG Menu title in First Play, and all should be fine.
Jérôme
Yes, VLC is the only player that shows a menu. Apple's DVD player and my set-top player skip the menu. How do I Add the Jump VMG Menu title in First Play?Originally Posted by [url=http://www.videohelp.com/tools/myDVDEdit
- Select the First Play PGC in the top-left list
- Select the First Play vertical tab
- Select the Pre-cmds tab
- Clic on the + button under the command list
- Clic on the small triangle button to edit the new command
- Change the command type from Nop to Jump/Call
- Change the command from Nop to Jump VMG Menu title
- Clic on the triangle to close the command editor
- Save
- Burn the DVD
- Enjoy
Maybe the read of my tutorial would help you to understand how DVDs and myDVDEdit works
http://www.mydvdedit.com/viewtutorial.php?t=16e
Jérôme.
how to skip main menu
By arumugam49 in forum Authoring (DVD)Replies: 3Last Post: 24th Oct 2010, 08:08 -
Fixing title menu buttons
By Yaro in forum EditingReplies: 4Last Post: 8th Sep 2009, 03:35 -
PLEASE HELP - DVD Menu Buttons - I dont even know where to start...
By sk8_aholic in forum Authoring (DVD)Replies: 6Last Post: 10th Sep 2008, 00:40 -
DVDLab Pro VMG and Menu Button and Chapter Skip on Remote
By raouliii in forum Authoring (DVD)Replies: 2Last Post: 20th Dec 2007, 13:08 -
Fixing DVD menu's
By demonwarrior in forum Newbie / General discussionsReplies: 9Last Post: 4th Sep 2007, 08:11
