Hi, I´ve been converting a few dvds recently, but today I was converting a vob, and for the first time, there was no audio!
If anyone could help me i'd be forever thankfulFIXME:Hardenabling SSE and SSE2 without detection
Wed Dec 23 19:19:29 CET 2009
MEncoder dev-CVS-060307-04:23-4.0.1 (C) 2000-2006 MPlayer Team
Mac OSX static build for ffmpegX
CPU: Intel Pentium III Katmai/Pentium III Xeon Tanner (Family: 6, Stepping: 10)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
success: format: 0 data: 0x0 - 0xa87ea800
MPEG-PS file format detected.
Maybe you are playing a non-interleaved stream/file or the codec failed?
For AVI files, try to force non-interleaved mode with the -ni option.
Too many video packets in the buffer: (4096 in 8269228 bytes).
MPEG: No audio stream found -> no sound.
VIDEO: MPEG2 720x576 (aspect 2) 25.000 fps 5527.2 kbps (690.9 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x576 fps:25.00 ftime:=0.0400
xvid: using library version 1.2.-127 (build xvid-1.2.0-dev)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=640 h=352]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
The selected video_out device is incompatible with this codec.
Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
VDec: vo config request - 720 x 576 (preferred colorspace: Mpeg PES)
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm: libmpeg2 (MPEG-1 or 2 (libmpeg2))
VDec: vo config request - 720 x 576 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using MMX2
videocodec: XviD (640x352 fourcc=44495658 [XVID])
xvid: par=0/0 (vga11), displayed=640x480, sampled=640x352
xvid: CBR Rate Control -- bitrate=1265kbit/s
1 duplicate frame(s)!
Writing header...
ODML: vprp aspect is 4:3.
Writing header...
Writing header...
Flushing video frames
Writing index...
Writing header...
Video stream: 1263.127 kbit/s (157890 B/s) size: 617991408 bytes 3914.040 secs 97851 frames
Encoding completed on Wed Dec 23 19:59:35 CET 2009![]()
Thread: Vob to avi, NO SOUND
1/ When you encode with a mencoder preset, you may use the VIDEO_TS folder as input.
2/ Try the [Play] button before the conversion. If built-in mplayer doesn't give sound when playing, then a mencoder conversion will likely lack sound as well.
3/ If mencoder has trouble with your source, regardless of settings, then try the XviD ffmpeg preset.
No subtiltes no sound - Converting Avi to VOB using AVStoDVD - no success
By Ze Tomes in forum Video ConversionReplies: 7Last Post: 23rd May 2011, 23:23 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 08:59 -
MKV To Vob with AC3 Sound.
By madman1987 in forum Video ConversionReplies: 4Last Post: 23rd Dec 2008, 09:54 -
VOB to AVI back to VOB
By fatla00 in forum Authoring (DVD)Replies: 23Last Post: 11th Oct 2007, 03:28 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 20:21
Statistics
Newest guides
Latest tool updates
New media comments
