I have been having some issues with the MMC software. What I would like to do is uninstall everything and re-install from the CD. I know I can use the uninstall tool obviously, but it still leaves traces on the computer. I want as clean of an uninstall as possible. While searching in cyberspace, I found this guide geared toward ATI products in general. Are these generally good recommendations? The guide isn't specific to the ATI AIW 9600. Any other suggestions for a clean uninstall?
http://www.rage3d.com/board/showthre...eadid=33606840
Thread: Clean uninstall of ATI AIW 9600
That guide is pretty old and may predate your particular version of MMC. You'll just have to try it and see if it works. The actions it recommends seem reasonable to me and should work, but I can't give you a 100% assurance that it will get everything or that you won't make a mistake and damage your PC. Do regedit stuff at your own risk.
I'm not particularly fond of ATI products and I don't recommend them. Hauppauge is a lot more user friendly.
There are two older programs I used years ago that were geared to removing ATI stuff off your computer that worked quite well for me. They were "cat-uninstaller.exe" and "nfr_072.exe" =nasty file remover. I don't know how well they will work in with your newer card.
That guide is good, I don't recommend using the software uninstall utility in ADD/Remove Programs or cat_uninstaller.exe because it might trigger Windows Product Activation. I uninstall the MMC first(without rebooting) then the CCC(without rebooting) and the display drivers last(then reboot).
After rebooting I run a registry cleaner such as Eusing.
Convert ATI AIW .vcr format to anything?
By madmartian in forum Video ConversionReplies: 14Last Post: 4th Jan 2012, 06:59 -
ATI AIW 7500 64M Replacement?
By TaranScorp in forum CapturingReplies: 20Last Post: 6th Aug 2009, 11:56 -
ATI ALL in WONDER 9600 TV & capturing problem
By ikeogut in forum CapturingReplies: 35Last Post: 31st Aug 2008, 04:51 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 13:25 -
ATI 7500 AIW capture problems
By saoneg in forum CapturingReplies: 8Last Post: 6th Mar 2008, 05:11
Statistics
Newest guides
Latest tool updates
New media comments
