I notice there can be an artifact in video that's been treated with the Thalen Deshaker that I would describe as a graininess in the image. It doesn't seem to effect the entire image uniformly, it seems to show up in certain areas and is most noticeable when there's panning movement. Any idea what causes this and how to eliminate it?
Can you post a before and after sample for comparison ?
Caused by the motion. The program is trying to estimate direction of motion. If the cam was handheld there was likely X-Y and rotational motion while deshaker assumed a straight line vector.Originally Posted by brassplyerRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
CLI batch Vdub Image Sequence
By corsiva in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2011, 12:49 -
VDUB, deshaker, output(compression) problem
By zzyzx2 in forum Video ConversionReplies: 2Last Post: 28th Apr 2010, 00:47 -
Vdub Thalen Deshaker Gets To Certain Point And Stops
By brassplyer in forum EditingReplies: 0Last Post: 31st Dec 2009, 07:12 -
Which is the best VDub filter to fix this video/image?
By zanos in forum RestorationReplies: 7Last Post: 12th Feb 2009, 16:37 -
Top border intrusion with Vdub Deshaker plugin.
By brassplyer in forum EditingReplies: 2Last Post: 6th Jan 2009, 10:29
Statistics
Newest guides
Latest tool updates
New media comments
