VideoHelp.com Forum
  1. Member mr nice's Avatar
    I just purchased Vob2Mpg from yourself, I have a problem when I ticked the chapter box then ran the program it extracted the 24 second clip when I played the clip all I got was a black screen. I normally use Meg2cut to do the same thing as your program. I did the exact same clip with Meg2cut and it worked perfect. Here is my log when I extacted using your program.
    ************************ SYSTEM INFORMATION ************************
    ***************************** VOB2MPG *****************************
    Title: PRO
    Version: 3.0.0131
    Executable: C:\VOB2MPG PRO\VOB2MPG.exe
    Executable size: 853 KB
    Executable size in bytes: 874067
    Executable CreationTime: 12/11/2009 21:40:00
    Executable LastWriteTime: 12/22/2009 22:02:59
    Executable LastAccessTime: 12/23/2009 14:44:07
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    Size:
    FreeSpace: 4.11 GB
    DeviceID: D:
    FileSystem: NTFS
    Size:
    FreeSpace: 4.49 GB
    DeviceID: G:
    FileSystem: NTFS
    Size:
    FreeSpace: 25.0 GB
    ********************* END OF SYSTEM INFORMATION ********************
    /v="G:\Pie\VIDEO_TS" /t=22 /c=1 /o="D:\Title_22_Ch_1.mpg"
    14:51:36
    Extracting from Title: 22
    14:51:36 vPaths: G:\Pie\VIDEO_TS\VTS_04_1.VOB,G:\Pie\VIDEO_TS\VTS_0 4_2.VOB,G:\Pie\VIDEO_TS\VTS_04_3.VOB,G:\pie\VIDEO_ TS\VTS_04_4.VOB,
    14:51:36
    14:51:36 =============== Virtual File Details ===============
    14:51:36
    14:51:36 VTS_04_1.VOB : Length = 1073739776 (0.99 GB) : vPosition = 1073739776 (0.99 GB)
    14:51:36 VTS_04_2.VOB : Length = 1073739776 (0.99 GB) : vPosition = 2147479552 (1.99 GB)
    14:51:36 VTS_04_3.VOB : Length = 1073739776 (0.99 GB) : vPosition = 3221219328 (2.99 GB)
    14:51:36 VTS_04_4.VOB : Length = 476999680 (454 MB) : vPosition = 3698219008 (3.44 GB)
    14:51:36
    14:51:36
    14:51:36 Extracting chapter: 1...
    14:51:36 Start position: 0 End position: 16384
    14:51:57 Start position: 16384 End position: 32768
    14:52:05 Rate: 0.00MB/s (0.00Mb/s)
    14:52:05 Extracting chapter: 1... Done.
    14:52:06 Finished Processing...
    14:52:06 Duration (hh:mms): 00:00:31
    /v="G:\spidy2\VIDEO_TS" /t=22 /c=1 /o="D:\Title_22_Ch_1(1).mpg"
    14:53:29
    14:53:29 vPaths: G:\Pie\VIDEO_TS\VTS_04_1.VOB,G:\Pie\VIDEO_TS\VTS_0 4_2.VOB,G:\Pie\VIDEO_TS\VTS_04_3.VOB,G:\pie\VIDEO_ TS\VTS_04_4.VOB,
    14:53:29
    14:53:29 =============== Virtual File Details ===============
    14:53:29
    14:53:29 VTS_04_1.VOB : Length = 1073739776 (0.99 GB) : vPosition = 1073739776 (0.99 GB)
    14:53:29 VTS_04_2.VOB : Length = 1073739776 (0.99 GB) : vPosition = 2147479552 (1.99 GB)
    14:53:29 VTS_04_3.VOB : Length = 1073739776 (0.99 GB) : vPosition = 3221219328 (2.99 GB)
    14:53:29 VTS_04_4.VOB : Length = 476999680 (454 MB) : vPosition = 3698219008 (3.44 GB)
    14:53:29
    14:53:29
    14:53:29 Extracting chapter: 1...
    14:53:29 Start position: 0 End position: 16384
    14:53:49 Start position: 16384 End position: 32768
    14:53:57 Rate: 0.00MB/s (0.00Mb/s)
    14:53:57 Extracting chapter: 1... Done.
    14:53:57 Finished Processing...
    14:53:57 Duration (hh:mms): 00:00:29
    /v="G:\spidy2\VIDEO_TS" /t=22 /c=1,2 /o="D:\Title_22_Ch_1_2.mpg"
    14:54:53
    14:54:53 vPaths: G:\Pie\VIDEO_TS\VTS_04_1.VOB,G:\Pie\VIDEO_TS\VTS_0 4_2.VOB,G:\Pie\VIDEO_TS\VTS_04_3.VOB,G:\pie\VIDEO_ TS\VTS_04_4.VOB,
    14:54:53
    14:54:53 =============== Virtual File Details ===============
    14:54:53
    14:54:53 VTS_04_1.VOB : Length = 1073739776 (0.99 GB) : vPosition = 1073739776 (0.99 GB)
    14:54:53 VTS_04_2.VOB : Length = 1073739776 (0.99 GB) : vPosition = 2147479552 (1.99 GB)
    14:54:53 VTS_04_3.VOB : Length = 1073739776 (0.99 GB) : vPosition = 3221219328 (2.99 GB)
    14:54:53 VTS_04_4.VOB : Length = 476999680 (454 MB) : vPosition = 3698219008 (3.44 GB)
    14:54:53
    14:54:53
    14:54:53 Extracting chapter: 1...
    14:54:53 Start position: 0 End position: 16384
    14:54:53 Start position: 16384 End position: 32768
    14:54:53 Rate: 0.00MB/s (0.00Mb/s)
    14:54:53 Extracting chapter: 1... Done.
    14:54:53 Extracting chapter: 2...
    14:54:53 Start position: 32768 End position: 49152
    14:54:53 Extracting chapter: 2... Done.
    14:54:54 Finished Processing...
    14:54:54 Duration (hh:mms): 00:00:00
    /v="G:\Pie\VIDEO_TS" /t=22 /c=2 /o="D:\Title_22_Ch_2.mpg"
    14:55:16
    14:55:16 vPaths: G:\Pie\VIDEO_TS\VTS_04_1.VOB,G:\Pie\VIDEO_TS\VTS_0 4_2.VOB,G:\Pie\VIDEO_TS\VTS_04_3.VOB,G:\pie\VIDEO_ TS\VTS_04_4.VOB,
    14:55:16
    14:55:16 =============== Virtual File Details ===============
    14:55:16
    14:55:16 VTS_04_1.VOB : Length = 1073739776 (0.99 GB) : vPosition = 1073739776 (0.99 GB)
    14:55:16 VTS_04_2.VOB : Length = 1073739776 (0.99 GB) : vPosition = 2147479552 (1.99 GB)
    14:55:16 VTS_04_3.VOB : Length = 1073739776 (0.99 GB) : vPosition = 3221219328 (2.99 GB)
    14:55:16 VTS_04_4.VOB : Length = 476999680 (454 MB) : vPosition = 3698219008 (3.44 GB)
    14:55:16
    14:55:16
    14:55:16 Extracting chapter: 2...
    14:55:16 Start position: 32768 End position: 49152
    14:55:41 Rate: 0.00MB/s (0.00Mb/s)
    14:55:41 Extracting chapter: 2... Done.
    14:55:41 Finished Processing...
    14:55:41 Duration (hh:mms): 00:00:26
  2. Member ChrissyBoy's Avatar
    Can you email me the Title_22_Ch_1.mpg file and i will try to play it locally.... What are you using to play it?
  1. VOB2MPG PRO v3 - Windows 7 Problem
    By xtekm in forum SVCD2DVD & VOB2MPG
    Last Post: 1st Apr 2012, 10:00
  2. VOB2MPG Pro / Win 7 Pro 64-bit Service Pack 1 Problem?
    By Rich_A in forum SVCD2DVD & VOB2MPG
    Last Post: 2nd May 2011, 15:06
  3. VOB2MPG PRO viewing .vob problem
    By nautalis in forum SVCD2DVD & VOB2MPG
    Last Post: 10th Oct 2010, 12:26
  4. VOB2MPG PRO problem - freezes
    By bar1 in forum SVCD2DVD & VOB2MPG
    Last Post: 3rd Oct 2010, 22:04
  5. Unable to install VOB2MPG or VOB2MPG PRO
    By tooc in forum SVCD2DVD & VOB2MPG
    Last Post: 28th Mar 2010, 00:53
