VideoHelp.com Forum
  1. Member nick101181's Avatar
    Hi,
    I have a dvi to hdmi cable with analog audio going from my pc to my tv. I have a samsung 52" series 5 530. The only 3.5 mm audio in, is grouped with a vga input. With the cable I have my video coming thru but no audio when I have the 3.5 mm audio jack plugged into the 3.5 mm input. Any ides on how to get sound with the setup that I have?
    On my TV one of the HDMI inputs is paired to a set of RCA audio inputs, I have to use a 3.5mm stereo -> 2 x RCA cable to get any audio from the PC.
    Maybe your's has something similar?
  3. Mod Neophyte Super Moderator redwudz's Avatar
    Depends on the TV. Some seem to not accept a separate audio input, especially when you are using a HDMI input. You would have to check the TVs manual. I use a separate surround sound amp, so I don't use the TV sound at all. One option is to use PC speakers placed by your TV and use the audio out from the audio card on the PC. If you are viewing movies with 5.1 audio, the separate surround amp is really the better way to go, if you do want to enjoy surround sound.
  4. Member edDV's Avatar
    Check your menus to see if you can pair the VGA block audio to an HDMI input. If not, get a mini-plug to RCA stereo cable.
    http://www.kiva.org/about
  5. Member MOVIEGEEK's Avatar
    You might have to use VGA or get a videocard with HDMI.
    Redwudz idea about PC speakers is a good one, you can get a 2.1ch system for around $30. A SPDIF coax cable will also work if you have a AVR.
  6. Member nick101181's Avatar
    I noticed I do have hdmi out on my mobo. My mobo is an ASUSTeK Computer INC. M3A78-EM. I'm thinking if I'm going hdmi to hdmi, I should have sound as well, correct? I tried this and I get no sound from the tv. I also tried my dvi to hdmi with analog audio and it's not detected even when pairing it up to the corresponding rca audio input.
  7. Member edDV's Avatar
    Maybe sound. Probably not. If you need to loop sound cables to the video card then probably. If video is on the mother board, consult the motherboard documentation.
  8. Member nick101181's Avatar
    I got it figured out. I had to enable hdmi audio out in the bios. thanks everyone
  1. Replies: 16
    Last Post: 25th Feb 2012, 16:20
  2. Replies: 4
    Last Post: 14th Oct 2011, 08:31
  3. Plug DVI/HDMI adapter to DVI video card?
    By Stealth3si in forum Media Center PC / MediaCenters
    Last Post: 23rd Dec 2010, 19:32
  4. Need help with HDMI, DVI-HDMI and "high definition audio device"
    By uart in forum Newbie / General discussions
    Last Post: 16th Mar 2010, 00:15
  5. DVI - HDMI - DVI problem
    By rbjt in forum Media Center PC / MediaCenters
    Last Post: 4th Aug 2009, 23:14
