VideoHelp.com Forum
Thread: pixelated
    hey im harrison and iv made a little bmx edit and it came out quite pixelated ... does anyone know how i could get it to a better quality. i filmed it with a panasonic lumix (dmc-fs3) 8.1 megapixel and edited it with cyberlink power director. can anyone help. http://www.vimeo.com/8337991
    the link is to the video i made just so you can see how pixelated it is.
  2. Member edDV's Avatar
    Probably insufficient bit rate. Give encoding details.
    I'm seeing heavy frame loss (jerkiness) more than pixelation.
    http://www.kiva.org/about
    how could i fix the jerkyness
  4. Member classfour's Avatar
    What is your framerate? If you're running 15 fps, you'll see jerkiness.
    The video looks fine for an internet video - none of which I'd play on a 50 inch TV.
    As to the clarity of the video (jerkiness issue, perhaps): It appears to be encoded at too low of a framerate.
    You will have to encode at a much higher quality to eliminate this.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
  5. Member edDV's Avatar
    First shoot at maximum camera quality which seems to be 848x480p 30fps.
    Your camera shoots MJPEG (motion JPeg). Ideally you would use an editor that handles 30p timelines (not sure of Director). Export with sufficient bit rate to handle the high motion (~8Mb/s ave. MPeg2 or 4Mb/s ave. MPeg4).
    A camera that could do 60fps would do better for your camera style. Or, try to hold the existing cam steady.
    I downloaded the MOV file from Vimeo and it was 25 fps and played fairly smoothly (aside from the jerky camerawork, and the inherent jerkiness of 25 fps) with VLC. It did look like it was originally 30 fps and was converted to 25 fps by dropping every 6th frame. I don't know if you did that in your editor or if Vimeo did it while converting.
  1. Pixelated video problem on PC
    By blacksheepdownunder in forum Newbie / General discussions
    Last Post: 25th Sep 2010, 22:51
  2. Pixelated Video
    By toadzky in forum Newbie / General discussions
    Last Post: 7th Apr 2010, 03:28
  3. Authored DVD Pixelated
    By stingrai in forum Authoring (DVD)
    Last Post: 29th Nov 2009, 08:32
  4. Pixelated playback
    By bilbonvidia in forum Newbie / General discussions
    Last Post: 10th Oct 2008, 16:45
  5. Pixelated playback
    By Itachi75 in forum Software Playing
    Last Post: 31st Oct 2007, 21:23
