VideoHelp.com Forum
    I need to convert a couple of short .mov files to .flv but am having no luck. I get the progress bar pop up which shows the encoding is over is seconds. I tried converting the file to an .avi and that worked fine, but the flv files all show 0 kb in size when they're completed. I would really appreciate any insight or assistance anyone can give.
    Thanks in advance.
  2. Explorer Case's Avatar
    Please post the Process Information log for analysis. You may access this log by clicking the blue "i" in the ffmpegX Progress window after a conversion (attempt).
    Here's one of them:
    Encoding started on Tue Dec 22 12:41:57 EST 2009
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/helenbieber/Desktop/ WEB MOVIES/untitled folder/btl.mov':
    Duration: 00:03:50.3, start: 0.000000, bitrate: 646 kb/s
    Stream #0.0(eng): Audio: aac, 44100 Hz, stereo
    Stream #0.1(eng), 29.97 fps(r): Video: h264, yuv420p, 320x213
    Codec type mismatch for mapping #0.0 -> #0.0
    Many thanks! I'll give that a try.
    Please help : Im trying to invert mapping in QT Pro. When I get to this part it seems to confuse me ( Switch to the extracted Untitled soundtrack window. Select all. Copy (to clipboard). Switch back to the .mov window. Select all. Add (from clipboard) to movie ) Sorry Im such a dummy but what clipboard ? Can I save the untitled file to my desktop ? Do I convert it to a audio file from a QT file ? Plain and simple guys, I cant get this audio under the movie file. Please help! Im struggling with this.
  6. Explorer Case's Avatar
    Open your .mov in QTP. Show Movie Properties. Extract the soundtrack.
    [A new QuickTime 'Untitled' window will appear, that has just the audio.]
    Delete the soundtrack [from the original movie].
    [When you do ⌘C or Menu > Edit > Copy, whatever was selected will be copied in computer memory. Sometimes this is called the Clipboard or Pasteboard.]
    Switch back to the .mov window. Select all. Add (from clipboard) to movie.
    [Doing menu > Edit > Add to Movie (⌥⌘V) will put the the soundtrack back into the movie.]
    [The stream order is now video first, audio last, when audio was first before.]
    Save as self-contained .mov.
  7. Explorer Case's Avatar
    This can be checked by the ID numbers of the streams (QuickTime Player calls the streams 'Tracks') in the Properties window. The lowest ID number will signify the first stream.
  1. Squashed ffmpegx Flash Video in iWeb
    By IrishP in forum ffmpegX general discussion
    Last Post: 20th Jun 2011, 08:32
  2. ffmpegX gives me 0 byte flash file
    By flim in forum ffmpegX general discussion
    Last Post: 9th Apr 2010, 13:12
  3. Convert MOV to FLASH to a website ?????
    By macmithos in forum Mac
    Last Post: 3rd Aug 2008, 05:40
  4. MOV to MPEG-1 with ffmpegX on Mac; doesn't play on PC
    By mopkba12345 in forum Video Conversion
    Last Post: 20th Feb 2008, 10:52
