Hi guys, I'm new here.
I have a 1080p movie in .mkv format with multiple preloaded subtitle tracks in the .mkv file. I can select between the different subtitle tracks in VLC and that works. However, I would like to use MPC instead of VLC because I need GPU decoding to be able to play the file (CPU not powerful enough otherwise). I can't seem to find a way to even show the .mkv embedded subtitles with MPC. Does anyone know how to do this if it is possible?
Thank you.
Thread: .mkv subtitles in MPC
Try install haali media splitter and try also mpchc. And then check both under play->subtitles and navigate->subtitles.
Thank you Baldrick,Originally Posted by Baldrick
I don't know how I missed the Navigate->Subtitles menu. It works wonderfully. I feel like such an idiot.
Enjoy the holiday season.
MPC-HC, MKV and memory problem
By Docoptik in forum Software PlayingReplies: 7Last Post: 18th Mar 2012, 21:40 -
MKV embedded subtitles don't always load in MPC-HC
By aer in forum Software PlayingReplies: 0Last Post: 22nd Aug 2011, 18:53 -
MPC-HC and MKV playback
By tiger6969 in forum Media Center PC / MediaCentersReplies: 6Last Post: 28th Dec 2008, 17:58 -
No subtitles when playing a .MKV file in MPC HC
By THX-UltraII in forum SubtitleReplies: 5Last Post: 21st Aug 2008, 07:08 -
MeGui Encode - x264 / AC3 / MKV - No subtitles in MPC
By Shevek in forum SubtitleReplies: 1Last Post: 28th May 2008, 03:19
Statistics
Newest guides
Latest tool updates
New media comments
