I have some trouble creating a custom menu in TMPGEnc Authoring Works 4. I want a single still-picture menu that has links to play each track. I have 5 separate tracks. By going through the Menu Wizard, I can only create a title menu that has a link to the track menu. And the track menu has the links to each track. Is there a way for me to just have the title menu with links to play each track, no track menu?
This was possible in TMPGEnc DVD Author 3 but for some reason, I cannot find any option to do this in 4. Hopefully, someone can help me with this. Thanks in advance!
The menu type selection page is just after template selection (select proper number of buttons per top menu page there to get single page). Select 'Top menu only' in that next page.
In the menu composition setting also uncheck both boxes in title page use or it will make a second page for tracks even if top menu only is selected on all choices.
Ben Johnson-I didnt take any stereos!
I selected top menu only but there is no place for me to uncheck. Under Menu Composition, I am only able to select one out of Automatic, Top Menu Only, Track Menu Only, or Top & Track Menu.Originally Posted by johns0
Edit:
Nevermind, I found what you were talking about on the first setting of the wizard. Thanks guys, it worked!
TMPGEnc Authoring Works 4 Menu Help Needed
By VOYAGER2009 in forum Video ConversionReplies: 1Last Post: 15th Apr 2011, 12:37 -
TMPGENc Authoring Works 4 - motion menu no audio
By mobie29 in forum Authoring (Blu-ray)Replies: 3Last Post: 16th Jul 2010, 16:32 -
Menu question re: TMPGEnc Authoring works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 9th Jun 2010, 07:32 -
TMPGEnc Authoring Works 4 - Menu help
By NotSoEasy in forum Authoring (DVD)Replies: 9Last Post: 1st Mar 2010, 02:24 -
How do you add menu links in TMPGEnc Authoring Works 4
By philled in forum Authoring (DVD)Replies: 1Last Post: 27th Nov 2009, 09:47
Statistics
Newest guides
Latest tool updates
New media comments
