I have Windows XP, installed WMP 11.
I have tried ffdshow, CoreAVC, Haali Media Splitter, and Quicktime DirectShow Filter for WMP 1.0.16.
None of it is allowing me to play H264 files in my WMP.. I have tried dragging and dropping the file into the player AND opening the file manually from the menu.
I am about to rip my hair out because I don't know what I am doing wrong, I have followed configuration instructions and everything. I am willing to start from the top as long as it will work!
Please, please help.....
Rissa
Thread: H264 Playback Problems in WMP 11
have you considered it's just a badly made file and won't play at all? cut a piece and post it if you want help with it. or atl least post mediainfo -> text view information.
I just uninstalled all newly installed codecs and installed K-Lite Codec pack, all files play except for one (as you guessed) badly made file, obviously with some sort of CSS copy protection problem.
Before it wasn't playing anything, so I'm glad to have that figured at least.
You can always try a software player like VLC. It plays most all formats without adding problematic codec packs. It can also play some damaged files. If it works with your problem video, that will usually tell you if you are likely missing a codec or have some damaged ones, like what can happen when you toss in a codec pack or two.
If you want to add support for most codecs for programs like WMP, try ffdshow. It isn't a codec pack and causes few problems, and it lets you play most common video and audio formats.
And welcome to our forums.
Problems converting some xvid to h264 to append to another h264
By PlanetIndigo in forum Video ConversionReplies: 3Last Post: 6th Jun 2011, 14:13 -
why WMP refuse to read my h264 file ?
By dumoulex in forum Newbie / General discussionsReplies: 12Last Post: 15th Feb 2011, 08:46 -
How to play avi/H264 video file on WMP 12
By Tatl in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2010, 18:02 -
Sluggish WMP playback
By frogger012 in forum Software PlayingReplies: 2Last Post: 18th Jan 2010, 13:48 -
wMP 11 Playback
By lowfell in forum Software PlayingReplies: 5Last Post: 6th Jun 2008, 09:52
Statistics
Newest guides
Latest tool updates
New media comments
