Hi!
PLEASE CAN SOMEONE HELP?
After i added subtitles myself to an AVI file using subtitle workshop i checked and the timing of subtitles appear to be ok.
I then proceeded with filtering the subtitles and compressed my AVI file with my subtitles and saved it (steamed or dubbed).
When i get the compressed video file after a couple of hours i found out that the timing of the subtitles changed.
And the last subtitles of the movie show 27 seconds later than they should appear.
Can you please help me? What do you recommend?
Posted by Teamo1976
Thread: subtitles timing
Baldrick wrote> If you play the avi and the separate subtitle file with for example vlc or mpc. Is it synced?
How do you add the subs to the avi? what tools?
If i play it with vlc (after compression of course) it is not synched. But it looks very synched in subtitle workshop.
I use virtual dub to add subs. But i am adding them by myself for a special video (AVI file) with subtitle workshop.
Then i open VDub file and open the AVI, go to video filter, add sub's ass file and then compress it under the video menu.
I compress it with DIVx 6.8.5 codec 1logical cpu. When the DivX properties window shows up, i put 1358.207 as bitrate, and
10 as quality(ot sure if thats ok as bitrate for a 65 minutes movie).
After i save file as AVI though, the subtitles get out of synch. What do you recommend? Please help
Ps> Vitalspec suggested i compress the AVI before adding subs (i tried now but it didnt work)
By teamo1976
auto timing for subtitles any software
By userwords in forum SubtitleReplies: 0Last Post: 30th May 2010, 18:34 -
Syncing timing with additional subtitles?
By architectofpain in forum SubtitleReplies: 0Last Post: 6th Mar 2010, 01:16 -
Timing Subtitles from xls to srt
By tambor in forum SubtitleReplies: 3Last Post: 24th Feb 2010, 05:35 -
Error in DVDSubedit when re-timing subtitles
By kpic in forum SubtitleReplies: 2Last Post: 22nd Feb 2010, 04:08 -
timing off on extracted subtitles?
By ecc in forum SubtitleReplies: 0Last Post: 24th Feb 2008, 06:37
Statistics
Newest guides
Latest tool updates
New media comments
