Having just purchased the above machine, i am looking to make it MULTI-REGION so i can still play my R1 discs from the states. I have done a good search on here and google to find how to do it using the ONE-4-ALL RC but am somewhat confused. Can any of you learned chaps point me in the direction of a NOOB guide on how to achieve this ie a step by step guide. Also my last DVD player was multi-region'd by the use of a DISC that i got from Flea-Bay, Is the DISC method available for my BDPS360 and if so, can anyone point me in the direction of a download???
Look here:
http://www.videohelp.com/dvdhacks?dv...&Search=Search
[EDIT] That looks simple enough. At your own risk though and all that.Pull! Bang! Darn!
There NEVER has been a so-called "disc" method for making Sony DVD players region free. Follow the directions in frizti93's link and hope that it still works. Hardware and firmware changes by the manufacturer can break hacks that worked in the past. And Sony DVD players are currently among the most difficult in the world to unlock.
Thanks for the advice guys, most appreciated, one thing what model of one 4 all should i get???
dvd code to multi region my sony dvp-ns39
By fcooper in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2010, 18:52 -
Multi-region code needed for Sony SLV-D380P
By Rick Sailors in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Jul 2010, 20:29 -
Sony DAV-DZ265K- multi-region code required.
By alllleg in forum DVD & Blu-ray RecordersReplies: 1Last Post: 26th Mar 2009, 10:22 -
By alllleg in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Mar 2009, 06:12 -
Sony DVP-NC600 Multi-region question
By kc7gr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 9th Apr 2008, 09:10
