VideoHelp.com Forum
    Hello
    I have a High Def ( Cheap ) camcorder
    It produces files .MOV
    I have a file about 60 seconds long which is 162 Meg
    Vlc codec info for the MOV shows
    Resolution 1440x1080
    Frame Rate 29.9
    Now I convert to mpg using "SUPER"
    And the size drops to 14.8 Meg
    Vlc codec info for the mpg shows
    Frame Rate 29.9
    Any I don't think I can tell the difference in quality !
    Why the large difference in file sizes ?
    Does the mpg actually lose and quality ?
    Thanks Jim
    Use MediaInfo to look at the original bitrate and the new bitrate to see the difference. Yes, there will be a quality hit with a reduction of that size. How noticeable it will be depends on the content of the video, the screen you are viewing it on, the player you are using, and the state of your eyes.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
    Details below, how would I get a convention where the quality is the same ?
    General
    Complete name : C:\Users\jiml\Pictures\AmblesideDec2009\jim.MPG
    Format : MPEG-PS
    File size : 14.5 MiB
    Duration : 1mn 19s
    Overall bit rate : 1 527 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High 1440
    Format settings, BVOP : No
    Format settings, Matrix : Default
    Duration : 1mn 19s
    Bit rate mode : Variable
    Bit rate : 1 242 Kbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.027
    Stream size : 11.8 MiB (81%)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Duration : 1mn 19s
    Bit rate mode : Constant
    Bit rate : 224 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Stream size : 2.12 MiB (15%)
    Menu
    General
    Complete name : C:\Users\jiml\Pictures\AmblesideDec2009\FILE0029.M OV
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 158 MiB
    Duration : 1mn 19s
    Overall bit rate : 16.7 Mbps
    Encoded date : UTC 2009-12-11 13:39:09
    Tagged date : UTC 2009-12-11 13:39:09
    AMBA :
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 1mn 19s
    Bit rate : 0
    Maximum bit rate : 0
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Stream size : 157 MiB (99%)
    Title : Ambarella AVC / Ambarella AVC
    Language : English
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 1mn 19s
    Bit rate : 128 Kbps
    Channel positions : L R
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 1.21 MiB (1%)
    Title : Ambarella AAC / Ambarella AAC
    Language : English
    Different codecs have different compression abilities.
    Each compression with lossy codecs reduces quality. The losses may not be very visible if you use sufficient bitrate (ie, don't over compress).
  1. Home video to flv - quality loss and file size
    By Bain80 in forum Video Conversion
    Last Post: 20th Aug 2011, 19:08
  2. Can I get VOB to smaller file size with no loss of quality?
    By Joolz2020 in forum Newbie / General discussions
    Last Post: 23rd Aug 2010, 13:11
  3. MPG editing without quality loss?
    By spup345 in forum Editing
    Last Post: 20th Jan 2010, 16:15
  4. Replies: 3
    Last Post: 23rd Nov 2009, 23:45
  5. Replies: 3
    Last Post: 2nd Mar 2009, 22:46
