VideoHelp.com Forum
    The latest Haali Media Splitter http://www.videohelp.com/tools/Haali_Media_Splitter with "Added a 64-bit version"....
    1) Where is the x64 version? or it's included in the "MatroskaSplitter19122009.exe"
    3) I have MPC HC x64, must I also install ffdshow x64 for Haali Media Splitter to work? or can I just install Haali Media Splitter alone and it will work with my existing MPC HC x64?
    Thanks.
    1. Yep.
    2. Nope, you can use MPCHC built in codecs. You can also use MPCHC built in mkv/mp4 splitter so you really don't need haali, maybe for some mkvs/mp4s.
    Thanks Baldrick for the quick reply
    Yes, the internal built in codecs of MPC HC is good enough for me (mp4 clips), cause I don't have many mkv clips......., but if I want to test out if the latest Haali Media Splitter with x64 support is better than the default built in codes of MPC HC in playing mp4 clips, must I first install the ffdshow x64 or can I just simply install the latest Haali Media Splitter and it will work with my existing MPC HC x64 (without ffdshow x64)?
    Thanks again.
  1. FFMpegSource2 does not use Haali Media Splitter
    By wateshadon in forum Editing
    Last Post: 10th Sep 2010, 06:03
  2. Gabest MP4 splitter vs. Haali Media Splitter
    By jaduvil in forum Software Playing
    Last Post: 16th Jun 2010, 11:57
  3. Replies: 0
    Last Post: 3rd Mar 2010, 10:26
  4. ffdshow & Haali Media Splitter
    By AuroEdge in forum Software Playing
    Last Post: 26th Sep 2008, 00:18
  5. Haali media Splitter Errors
    By SWBisbee in forum Newbie / General discussions
    Last Post: 16th Sep 2007, 15:45
