We have a tower with VGA and USB inputs. It does not have HDMI or DVI. If we add a Blu-ray burner down the road, can we burn Blu-rays with VGA or USB? How do most of them hook up? Thanks.
Thread: Tower and Blu-ray burner hookup
If you have an usb2 input it should work fine.
Thanks Baldrick. I forgot to say before, it would be an internal Blu-ray burner. Does it matter what inputs are on the back of tower? Someone told me if it's an internal burner, the rear tower inputs aren't used.
Your question is sort of confusing. I think what you're asking is if you add a blu ray drive would your pc be able to burn blu-ray discs. You'll have to buy a blu-ray burner to have that capability. Blu-ray drives are hooked up inside a pc via a SATA connector on the motherboard.
If you're talking about playback of blu-ray movies then you don't need HDMI or DVI outputs unless you're hooking up your pc to a LCD/PLASMA TV.
Thanks budz. I'm talking about burning Blu-rays(if we add an internal Blu-ray burner) and watching them on a stand alone Blu-ray player. We DO NOT want to watch them on the computer. So it sounds like my tower would work. I thought it depended on the rear inputs on tower.
So you're saying you wanna back up your blu-ray movies on a blu-ray burner. Then play them back on a standalone blu-ray player? Why not just play them back on a standalone blu-ray player?
If your "tower" is more than three years old it may not function very well with a blu-ray burner. Blu-ray burners can be attached externally (usually via USB/Firewire) but they come in a separate enclosure and are more expensive than an internally fitted blu-ray drive, which will normally use a SATA connection. If your motherboard is older it may not have a SATA connector, just IDE. Best to give more details, nearer the time of purchase.... especially as the world is ending on dec21 2012
The great Biscuit Tower of Montezuma will come to life!
The electronic components of the power part adopted a lot of Rubycons.
LG BH10LS30 blu ray burner, Doesnt seem to recognise blu ray media
By john8611 in forum DVD & Blu-ray WritersReplies: 11Last Post: 5th Feb 2012, 03:58 -
Blu-Ray Burner Advice Please
By leebo in forum DVD & Blu-ray WritersReplies: 17Last Post: 14th Aug 2011, 23:09 -
LG Blu-Ray Burner only burning 2x BD-RE at 1.1x
By Lawbringer in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th Jan 2011, 20:24 -
Blu-Ray Burner Question and Help Please
By golfnut in forum DVD & Blu-ray WritersReplies: 7Last Post: 13th Sep 2010, 02:53 -
Blu Ray burner help
By dafoe in forum DVD & Blu-ray WritersReplies: 11Last Post: 8th Apr 2009, 00:14
