So I am about to buy all the parts to build my first HTPC, thanks for the suggestions from people who gave them. Now I just realized that the most import thing is that I do not have to move from my couch and that I do not want a keyboard lying around on my couch.
So what options do I have for a useful remote control?
What do I look for in a remote?
Results 1 to 9 of 9
I use a Soundgraph iMon remote. Can't tell you how it compares to others, as it's all I've used and am happy with it. I have the "Knob", there's also one with the sensor in a module you put in an unused external bay on your tower if you'd prefer.
For some applications, for example Digital Theater in TME, all that is necessary is to enter the executable in the remote's app launcher. All multimedia buttons work. For others, for example, MPCHC, it's necessary to enter the keyboard shortcuts (listed in MPCHC options) for each multimedia button. Isn't as tedious as it sounds. :P
Here's a couple links:
http://www.remotecentral.com/imon/index.html
http://www.digitalconnection.com/pro...mon_inside.asp
Good luck.
Pull! Bang! Darn!
If you purchase a Hauppauge HDTV Tuner card a MCE remote is includedOriginally Posted by aberthol
http://www.newegg.com/Product/Produc...82E16815116033
ocgw
peaceAthlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
http://forum.videohelp.com/topic368691.html
Hauppauge HDTV tuner cards aren't automatically bundled with a remote. They usually offer a kit that includes a remote, but may also offer the same card without a remote for a bit less. Shoppers need to read the description to find out what is included in the box.Originally Posted by ocgw
http://www.newegg.com/Product/Produc...82E16815116009.
You can download rc codes from the net thru usb to Logitech backlit remotesOriginally Posted by aberthol
http://www.buy.com/retail/product.as...ingid=63421789
A backlit keyboard like my Logitech G-11 can come in real handy
http://www.logitech.com/index.cfm/ke.../5902&cl=us,en
some wireless keyboards have "track balls"
http://www.google.com/products/catal...d=0CC0Q8gIwAQ#
ocgw
First you choose PVR software, then see their website for remote options.
http://www.kiva.org/about
Maybe I'm just unlucky, but the two PVR remotes I've had were utter crap.
First one came with a Leadtek Winfast HDTV Cinema card. Didn't even work, probably a faulty IR sensor. Then the remote bundled with my Hauppauge HD-PVR. That one works, but is far inferior to the iMon. [shrugs]
But yeah, get your PVR and see if the remote (if included) suits your purposes. I should add that I also have a wireless keyboard and mouse. You can do many things with a good HTPC remote, but it can be cumbersome to use for web surfing, etc.Pull! Bang! Darn!
Is the best to go about this really a wireless keyboard and mouse? Or can I really get a lot of function out of a remote control?
LIAN LI Black Aluminum PC-C37B Micro ATX Media Center / HTPC Case – Retail
http://www.newegg.com/Product/Produc...82E16811112186
this is the case I was going to get, should I not get that one and get a case that has two 5.25" drive bays so I could install a remote that needs a 5.25" drive bay for the remote control?
We are not saying a wireless kb and mouse is better than a remote or vise-versa, you need all three imoOriginally Posted by aberthol
and a joystick
and a thruster
and foot pedals
and a force feedback steering wheel
lol
ocgw
i need an IR/RF remote control for PC
By econtrerasguzman in forum ComputerReplies: 8Last Post: 19th Apr 2007, 23:35 -
Remote Control?
By Mattyl110792 in forum Media Center PC / MediaCentersReplies: 2Last Post: 25th Mar 2007, 20:34 -
looking for remote for PC/HTPC
By pglenn in forum DVB / HDTVReplies: 4Last Post: 28th Dec 2005, 09:10 -
Remote Control
By DanielXB in forum Software PlayingReplies: 1Last Post: 5th Jun 2004, 12:35
