Hello, i just downloaded FFmpeg and mpeg2enc. I browsed binaries loc on my mac desktop and confirmed. I got an error saying that the install was not successful. So i deleted the binaries file and re-opened FFmpeg. Even if it was not installed well, mpeg2enc is black (not red like for other 2 missing files). Means it's detected somehow. I can still convert files. How do i remove it?
Move /Library/Application Support/ffmpegX/mpeg2enc to the trash.
The fact is that i don't have the ffmpegx folder in application support, so i wondering where that file could be..
Mac OS X has active 3 Library folders.
• one in your Home folder or User directory; contains stuff for the current user only (I think you may have checked this one)
• one in the System folder; contains stuff from Apple only
• one in the root of the boot volume; contains stuff for all users and/or admin accounts (ffmpegX installs stuff into this one)
Code:Macintosh_HD/Users/username/Library often noted with a tilde: ~Library Macintosh_HD/System/Library often noted with a slash: /System/Library Macintosh_HD/Library often noted with a slash: /Library
I just checked all of these 3 library folders and none of these does have ffmpegx folder inside.
If mpeg2enc wasn't copied to /Library/Application Support/ffmpegX/ by the installer, then I can't explain why mpeg2enc would be listed in black.Originally Posted by svkrzn
Some conversions do not require mpeg2enc, mencoder or mplayer.Originally Posted by svkrzn
To re-install ffmpegX, you do not have to delete any file. The installer will overwrite any installed binary if it has the checkbox set in the installer window.
Can't install binaries for ffmpegX 0.0.9y
By kostas1969 in forum ffmpegX general discussionReplies: 2Last Post: 21st Feb 2012, 12:14 -
Newer Binaries?
By theorik in forum ffmpegX bugs and suggestionsReplies: 0Last Post: 30th Sep 2008, 02:39 -
installing Binaries
By mahanpots in forum ffmpegX general discussionReplies: 1Last Post: 14th Dec 2007, 10:16 -
Error while installing binaries!?? help!
By mavenny in forum ffmpegX general discussionReplies: 7Last Post: 8th Oct 2007, 22:29 -
Latest OS X reallib binaries?
By Scallywag in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jun 2007, 17:26
