VideoHelp.com Forum
Results 1 to 10 of 10
    I have some video cassetes miniDV in SD quality. I have transfered them with firewire to my PC as DV avi. I want to create a BD containing as much as possible from my videos, not as data but with menu etc. How can I achieve that?
    give this a try. multiAVCHD
    I did but it gives me an error when I try to add a video file "Invalid floating point operation"
    a win98 piii is not going to cut it in the blu-ray world.
    sorry my profile is not updated. I try to run it under winXP pro
  6. Member ricardouk's Avatar
    convert your videos to mpeg2/ac3 and create some menus with one of the dvdauthor guis available here on the tools section, i read that a bd player can read dvds/structure, but this way you get more than 4.4 GB on a disc, you can fit way more than the normal 1 or 2 hours that you can get with dvd.
    I love it when a plan comes together!
    Ricardo Santos
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    multiavchd wont work for avi files.
    Probably easiest is to use an all-in-one blu-ray authoring tool like tmpgenc authoring works.
  8. aBigMeanie aedipuss's Avatar
    sorry. they're right. first make dvd spec mpeg-2. then go to multiavchd if you want to put it on blu-ray. but, it's not going to look any better than dvd, and it's going to cost a hell of a lot more, so i'm not sure why you'd want to anyway.
    The reason I am trying to do this, is to put as more as I can video on a BD without losing quality. I don't care for the cost, as these cassettes are precious memories. The use of tmpgenc is not giving me more than 3 hours of play when I choose creation of BD and it is suposed that we can many more hours of video on a BD (or not?)
  10. Member ricardouk's Avatar
    using videohelp bitrate calculator:
    http://www.videohelp.com/calc.htm
    you can put 7 to 8 hous of footage with video bitrate around 7500kbits and ac3 stereo at 348k.
    or try avs2dvd it does offer some simple static/motion menus and select a custom size for your dvd, the size of your bd disc
    Ricardo Santos
  1. MiniDV video capture - on screen time/date stamp transfer
    By Logan69 in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 29th Feb 2012, 14:02
  2. Replies: 29
    Last Post: 29th Sep 2011, 03:39
  3. Sony HC3 firewire port dead,cheap miniDV camcorder to use for transfer?
    By alegator in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 13th Jul 2011, 19:59
  4. Replies: 0
    Last Post: 24th Dec 2007, 08:25
  5. Transfer miniDV to hard drive. Does it matter what software is used?
    By vid83 in forum Newbie / General discussions
    Last Post: 11th Dec 2007, 19:08
