VideoHelp.com Forum
    Here is my issue:
    I have a HTPC that I use Beyond TV 4 to watch and rec. TV. I just bought an LG Blu-ray player. The video card is made by Gigabyte the chipset is an Nvidia GeForce 7600 GS, which is supposed to have HDCP support. I have a Toshiba 42" Regza 42HL167. This TV has 3 HDMI connections that are supposed to be HDCP compatible.
    I just bought a cable from newegg that is also supposed to be HDCP compatible. I cant play any movie that has HDCP. So what am I missing?
    When I run Cyberlink's Blu-ray Disc Advisor it tells me that my video card supports HDCP, but it recommends upgrading. It also says that my Video Connection Type is Digital (without HDCP).
    I'm not sure what else to do. Everything I have supports HDCP but it will not work.
    Here is what I have:
    Toshiba Regza 42HL167 http://reviews.cnet.com/flat-panel-t...-32306263.html
    HDMI to DVI cable http://www.newegg.com/Product/Produc...82E16812186093
    Gigabyte 7600GS http://www.newegg.com/Product/Produc...82E16814125028
    LG BD-R http://www.newegg.com/Product/Produc...82E16827136175
    Also if I use AnyDVD demo I can watch Blu-Ray movies, I just don't want to have to buy it when everything should work.
    Thanks for any help.
  2. Member MOVIEGEEK's Avatar
    My guess the problem is your videocard, on newegg it doesn't say "HDCP Ready". Try a nVidia driver update, if that doesn't help then buy a new videocard with HDMI output.
    http://www.nvidia.com/Download/index.aspx?lang=en-us
    http://www.newegg.com/Product/Produc...82E16814125263
    BTW:AnyDVD works because it's stripping away any encryption, it might be worth buying if you plan on backing-up your Blu-ray's.
    Yeah, if you go to the Gigabyte web site it explicitly mentions HDCP compatibility for many cards. It doesn't mention HDCP for the GV-NX76G256D-RH.
    Note that many cards in the past were advertised as "HDCP compatible". Unfortunately, all that meant was the GPU was compatible with an external HDCP encryption chip. But those cards didn't include the HDCP chip. Some didn't even have a socket for one so adding one wasn't even an option.
    AnyDVD also removes "the need" for HDCP compliancy, I had all HDCP hardware and could not clone desktops (from PC monitor to HDTV) w/ blu ray because that is not allowed under HDCP, AnyDVD fixed that rediculus limitation
    btw Slysoft is offering AnyDVD HD @ 20% off w/ lifetime updates until the end of the year
    ocgw
    peace
    Athlon II Propus 630 @ 3.62Ghz / 8GB DDR2 1066 5-7-7-20 / 8x BD-RW / 19TB Storage
    http://forum.videohelp.com/topic368691.html
  1. Will my HP Pavilion a6220n work as a HTPC/server?
    By zeek543 in forum Media Center PC / MediaCenters
    Last Post: 27th Dec 2009, 22:26
  2. HDCP troubles...
    By AKA510 in forum Blu-ray Ripping
    Last Post: 27th Nov 2009, 08:12
  3. HDCP
    By Baldrick in forum Glossary
    Last Post: 29th Jan 2009, 07:27
  4. HD HTPC and hdcp ?
    By bluraid in forum Media Center PC / MediaCenters
    Last Post: 27th Feb 2008, 02:52
  5. BUILDING HTPC To work with Hauppauge MediaMVP
    By THE_oldguy in forum Media Center PC / MediaCenters
    Last Post: 29th Sep 2007, 22:25
