So since YouTube switched to using a more recent version of Flash, YouTube can't be viewed in the device's browser and FLVs downloaded from YouTube can't be played natively. That makes sense. Here's what doesn't: Downloading the source MP4 file (H.264 video/AAC audio) via YouTubeLoader.com and playing it on the device (with the Video Podcast plug-in) doesn't work either.
Any ideas?
Thanks!
Don't you need a h264 plugin for the archos? Or maybe you have it already?
And please also post the details from the mp4(mediainfo, view->text).
I have the proper plug-in (Video Podcast plug-in = H.264 and AAC playback).
Mediainfo details for a YouTube MP4:
Code:Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 File size : 8.20 MiB Duration : 1mn 55s Overall bit rate : 593 Kbps Encoded date : UTC 2009-12-09 03:19:35 Tagged date : UTC 2009-12-09 03:19:35 gsst : 0 gstd : 116470 gssd : B4A7DD326MH Video ID : 2 Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L3.0 Format settings, CABAC : No Format settings, ReFrames : 1 frame Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1mn 55s Bit rate mode : Variable Bit rate : 539 Kbps Maximum bit rate : 819 Kbps Width : 480 pixels Height : 360 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.104 Stream size : 7.45 MiB (91%) Title : (C) 2007 Google Inc. v08.13.2007. Encoded date : UTC 2009-12-09 03:19:35 Tagged date : UTC 2009-12-09 03:19:35 Audio ID : 1 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Format settings, PS : Yes Codec ID : 40 Duration : 1mn 55s Bit rate mode : Variable Bit rate : 51.3 Kbps Maximum bit rate : 59.0 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Resolution : 16 bits Stream size : 729 KiB (9%) Title : (C) 2007 Google Inc. v08.13.2007. Encoded date : UTC 2009-12-09 03:19:35 Tagged date : UTC 2009-12-09 03:19:35
Thanks! I'll try that.
Now if I could only figure out why the 605 won't see MP4s over UPnP that it can play locally.
This worked, by the way, in case anyone else had a similar issue and needed to fix it.
(I used the installer version of Yamb)
I have a similar problem. I have an Archos 605 Wi-Fi 160gb model and it suddenly stopped playing Youtube files. At dailymotion.com it gives me the dreaded Flash9 logo with means it wants me to have at least flash 9.
Any help would be greatly appreciated.
Archos 605 Video Encoding
By DJboutit in forum Video ConversionReplies: 4Last Post: 27th Dec 2009, 14:38 -
[Archos 605] transform from 720p.HD.DVDRip.XviD.AC3 to Archos format ?
By birdwing in forum Portable VideoReplies: 2Last Post: 5th Nov 2009, 23:41 -
Archos 605 Wifi Video Help H.264
By BladedDragon in forum Video ConversionReplies: 5Last Post: 16th Sep 2008, 08:14 -
help with my archos 605
By mustang1967 in forum Video ConversionReplies: 4Last Post: 27th May 2008, 21:43 -
testing surfing on my archos 605
By Baldrick in forum TestReplies: 0Last Post: 31st Mar 2008, 11:50
