    I have a small 1 minute HD clip that was produced for a client of mine. It is currently a .mov file. I had planned to convert it to Flash video for use on the web, but I can't even get Quicktime Player 10 or 7 to play this video. I can with VLC. I only have iMovie, and it can't open it, nor can the Adobe Media converter
    Quicktime's error sends me to http://support.apple.com/kb/HT3523
    Which suggest it is a Apple Intermediate Codec. And below is the video info "MediaInfo Mac" shows me.
    I would go back to the company that shot the video but it took 3 months to get the clip I have.
    So is there anything that can convert this into usable format, so I can play it with QT and I can finally convert it to Flash Video.
    *** MediaInfo Mac // Plain text file report
    2009-12-18 10:24:03 -0800
    Information for File: Jesse_Daniel_Salon_5thcut__.mov
    General / Container Stream # 1
    Total Video Streams for this File -> 1
    Total Audio Streams for this File -> 1
    Video Codecs Used -> hdv2
    Audio Codecs Used -> PCM
    File Format -> MPEG-4
    Play Time -> 1mn 0s
    Total File Size -> 190 MiB
    Total Stream BitRate -> 26.6 Mbps
    Video Stream # 1
    Codec (Human Name) -> hdv2
    Codec (FourCC) -> hdv2
    Frame Width -> 1 440 pixels
    Frame Height -> 1 080 pixels
    Frame Rate -> 29.970 fps
    Total Frames -> 1801
    Display Aspect Ratio -> 16/9
    QF (like Gordian Knot) -> 0.536
    Video Stream Length -> 1mn 0s 93ms
    Video Stream BitRate -> 25.0 Mbps
    Video Stream BitRate Mode -> VBR
    Video Stream Size -> 179 MiB (94%)
    Date of Original Encoding -> UTC 2009-09-24 01:45:41
    Audio Stream # 1
    Codec -> PCM
    Codec (FourCC) -> sowt
    Audio Stream Length -> 1mn 0s 93ms
    Audio Stream BitRate -> 1 536 Kbps
    Audio Stream BitRate Mode -> CBR
    Number of Audio Channels -> 2
    Sampling Rate -> 48.0 KHz
    Bit Depth -> 16 bits
    Audio Stream Size -> 11.0 MiB (6%)
    Try mpeg streamclip, avidemux or handbrake. And convert it to mp4 with h264 video and aac audio, it's supported by flash.
  3. Member Soopafresh's Avatar
    Edit - Sorry, my suggestion was wrong.
    "Quality is cool, but don't forget... Content is King!"
    FourCC 'hdv2' means Apple HDV 1080i60. You need AppleHDVCodec component installed with Final Cut Pro. VideoSpec would have given you this info.
    houdini
    Tied all 3 of these with no luck
    houdini
    Yep thats what apple support article said.
    So is there no way to work with the file without Final Cut Pro?
  7. try this codec (it's a perian hacked codec) http://blog.lib.umn.edu/mcfa0086/dis....component.zip
    you could display your HDV inside QuickTime BUT QuickTime is a pain with interlaced anamorphous stream (like your HDV ). Result should be mess up = mixed fields (but for a flash video with a little size, it should be OK)
    bye
    Edit: this codec seems not compatible with the new Perian1.2, so activate it only depending on your needs (personnally I use Diablotin to enble/disable quickTime codecs http://s.sudre.free.fr/Software/files/diablotin.dmg.gz)
    Some drawings ? http://www.whynotflores.com/. A software for DV, DVD-Video, HD files (AVCHD/…): http://www.movieconverter-studio.com/ 1.6 (2010/08)
  1. Replies: 8
    Last Post: 14th Mar 2008, 20:07
  2. cannot write medium-incompatible format
    By gabbybrin in forum Newbie / General discussions
    Last Post: 20th Dec 2004, 22:33
  3. Cannot write medium - incompatible format on NEC ND-1300A
    By Eurosur in forum Authoring (DVD)
    Last Post: 6th Jan 2004, 19:10
  4. Somehow convert incompatible mpeg files to common format?
    By joeAgain------ in forum Video Conversion
    Last Post: 2nd Jul 2002, 10:47
  5. Burining a vcd - incompatible format
    By strahey in forum Authoring (VCD/SVCD)
    Last Post: 23rd Aug 2001, 08:28
About   Advertise   Forum   RSS Feeds   Statistics   Tools
