Hello,
I've been doing a lot of reading on this site, and I've learned a lot. But I think it's time to just ask this question. I have Angels and Demons on Blu-Ray. I've used MakeMKV, Ripbot264, BR-Rebuilder, and Handbrake. I rip the entire movie using AnyDVD HD. From there, all I want to be able to do is just have the movie, keep it in FULL 1080p, and have forced subtitles. The size of the file is not an issue for me. I can always buy more HDD if I need more space.
I like MakeMKV, because it doesn't compress the file, so there is no loss of quality (at least that's what I think is happening), but I can't get forced subtitles with MakeMKV.
I like BR-Rebuilder since it gives me the option to keep forced subtitles on, along with keeping just the main title. However, I don't want it to shrink the file and have loss of quality, and there is no option for me to just have it do it's thing without telling it to output it in a certain size.
I liked Ripbot264, but the only problem I had with that is if once in a while I wanted to convert one of the blu-rays or even my normal DVDs to MP4 to play it on the AppleTV, and I would select the "Apple TV" preset, the movie looks horrible on the Apple TV. It's blurry, lagging, exploded pixels. But for some odd reason, when I use the pre-set "Apple TV" in Handbrake (0.9.4), load it to the Apple TV, it works perfectly. Also, it would be compressing the file, and I'd prefer a uncompressed file to prevent loss of quality.
I prefer not to use Handbrake, because for me, at least, it's very unstable on my Windows 7 x64.
So, my question is, does any one know a way, program(s), tips, advice - where I can just take my ripped Blu-Ray and have it be converted it to full 1080p WITH forced subtitles and WITHOUT any quality loss?
Thank you in advance.
Use MakeMKV as usual and then rip the subtitles separate, see http://forum.videohelp.com/topic376803.html . Then add the srt or sub/idx to the mkv using mkvtoolnix.
Thanks for the help. I have another question. When I scan for subtitles for Angels & Demons, I get a ton of subtitle files to pick from. Is there a program that can show me which subtitles are the forced ones so I can just extract them?Originally Posted by Baldrick
Help extracting forced subtitles from Sherlock Holmes (2009) blu-ray
By vtpeters in forum SubtitleReplies: 10Last Post: 14th Feb 2012, 17:32 -
Blu-ray Forced Subtitles
By jedisinclair in forum DVD RippingReplies: 4Last Post: 14th May 2010, 05:01 -
Forced subtitles english Blu Ray Avatar
By Modify_inc in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2010, 22:31 -
No forced subtitles on blu ray rip
By dreborn in forum Blu-ray RippingReplies: 2Last Post: 26th Oct 2009, 16:55 -
Forced Subtitles in M2TS - Blu-ray Ripped to HDD
By saber001 in forum Blu-ray RippingReplies: 4Last Post: 23rd Mar 2009, 06:14
Statistics
Newest guides
Latest tool updates
New media comments
