how to i display srt & sub subtitle files on media player classic??
yes i have tried the following but it doesnt work:
View-options-playback-output-'Check'-VMR7 (renderless)**
I then right clicked on the main video screen, went to subtitles - it is GREYED OUT. WHAT DO I DO?? Please help
and also how do i take snapshot image of the video? in all formats e.g. jpg bmp gif etc..???
Please answer the above two questions as soon as possible. Thank you.
Results 1 to 11 of 11
make sure the sub name is the same as the video name
ex:
video.avi
video.srtI love it when a plan comes together!
Ricardo Santos
i tried that before, it still does not work.Originally Posted by ricardouk
Can you open the SRT subtitles in an editor and see them? If they are not readable, the problem is that your computer does not support the character set that they use.
Your emergency is not our problem. Nobody gets paid to answer your questions. Asking us to answer your questions as soon as possible is not only a bit rude, it may actually make people not want to help you. Other people have problems too and want help and they don't ask us to answer them as soon as possible.
Some programs that can play videos have an option to take a screenshot. I know that older versions of PowerDVD can do this. VLC might also be able to do this. I don't know about MPC.
Firstly thank you for answering my question, yes i have edited the srt and sub files in Notepad and i have used VLC Media Player before, that is the reason why i want to use media player classic instead - if i cannot get srt subtitles to work or take snapshots, then ill have to go back to using vlc media player.Originally Posted by jman98
The reason why i dont want to use vlc media player is because it uses a lot of memory, and i cant seem to use the old version, when i install an older version i get an error message.This has just started to happen last week. anyway, i apologise for being rude, and yes i shouldnt have said as soon as possible, i didnt think id get any reply thats why.
Anyway, thanks for your message, i think im gonna stick to vlc media player anyway. i think its the only easiest multimedia player out there to use.
Do you have DirectVobSub/vsfilter installed?
For taking snapshots in Media Player Classic/MPC-HC, go to File > Save Image... (or hit Alt+I). You'll have the option to decide whether you want the snapshot in BMP, JPEG or PNG format when the Save As box pops up (use the Save as type: dropdown).If cameras add ten pounds, why would people want to eat them?
thank you for that it worked, i still cant get the subtitles to work.Originally Posted by Ai Haibara
Try the subs with VLC. If they work, then your problem is specific to MPC. If they don't work, the problem is specific to the subs. Are they in a foreign language by any chance? If so, what language? If they are not in a Western European language that uses the Latin alphabet, what character set are they in? You may not know the character set, but if you do it can be helpful to mention that.
How did you get the subtitles file? Did you create it yourself or download it from somewhere? Is there any chance that it was created on a non-Windows (ie. Mac or Linux) system? I've seen weird problems on DVD players with SRT files when the SRT file was edited on Linux. The because the end of line character is different between Linux and Windows.
Unicode can be a problem with some programs, but I think that Unicode subs should work OK. Not sure, but I think so.
Yeah they work well on VLC Media Player, im not new to using digital subtitles by the way, ive used .SUB .SSA & .SRT files with .avi files playing on vlc media player. I downloaded the srt/sub files from divx subtitles websites like:Originally Posted by jman98
opensubtitles.com
anysubs.com
And the language is always english. And yes your right, the problem is with MPC, but i dont know what it is. Another user here on this forum had the same problem as me, he used a software tool called VobSub or something, i tried that but still didnt work. Anyway im using Windows XP. Thanks for your reply.
Have your run both MPC and MPCHC? They both use the same registry key for subtitle settings but the values are incompatible. After running MPCHC the location, colors, etc of the subtitles are wrong in MPC and they may be rendered completely outside the window (so you don't see them). Try deleting \HKEY_CURRENT_USER\Software\Gabest\Media Player Classic\Settings\SPDefaultStyle in the Registry. MPC will reset the defaults when started.
I tried that, it didnt work.Originally Posted by jagabo
NBOX media player doesn't display the spanish subtitles srt properly
By leonardo07746 in forum Media Center PC / MediaCentersReplies: 0Last Post: 20th May 2011, 09:08 -
Frame count display in Media Player Classic? Or something else?
By Hoser Rob in forum Software PlayingReplies: 2Last Post: 10th Apr 2011, 10:59 -
Srt subtitles don't show with Media Player Classic- Please help
By jimdagys in forum SubtitleReplies: 6Last Post: 18th Jun 2009, 11:31 -
Media Player Classic and .srt
By marioval in forum SubtitleReplies: 1Last Post: 11th Oct 2007, 14:17 -
Media Player Classic + SRT Subtitles
By Basketbits in forum SubtitleReplies: 3Last Post: 17th Jul 2007, 03:53
