I've been attemping to get my DVC 170 to work for
awhile now and I'm still having no luck. I installed
the corret drivers meaning I installed the
"PCLEUSB2x32.exe" and then restarted. Then plugged in
the device and Windows installed its own which I found
a bit weird.
I then attempted to update the driver and pointed it to
the "PCLEUSB2x32.exe" and it found that the DVC 170
already had the latest driver. So I thought fine I'll
try and used it plugged in my 'Y Splitters', 'Xbox 360
Composite Connectors', and the AV Output cable into my
HDTV. I tried the device it two different programs
'Windows Movie Maker' and 'Song Vegas Platinum 9' and
got an error in both which I believe to stem from the
same problem.
Anyone know what is wrong or how to fix it, by the way
I'm using Windows 7 32-bit.
Thanks in advance![]()
I don't think there are drivers for Windows 7 with it yet? Not sure...
I have the same exact problem... Anyone got a solution...?
I believe both windows movie maker and sony vegas expect a DV device that is connected with firewire to the computer and can not use an USB capture device like dazzle dvc-170 that is limited to MPEG1/MPEG2/MPEG4 formats.
http://www.pinnaclesys.com/PublicSit...latinum+US.htm
I actually happen to have another device from Pinnacle 710USB which works just fine with both of the programs you mentioned kpa...
Two Quick Questions about Dazzle DVC 100
By Derangedyeti in forum CapturingReplies: 17Last Post: 23rd Dec 2010, 22:46 -
Dazzle DVC 90 Capturing
By LangleyM in forum CapturingReplies: 2Last Post: 19th Apr 2009, 09:42 -
Better than Dazzle DVC-170?
By bmbsa in forum CapturingReplies: 5Last Post: 21st Sep 2008, 06:18 -
Dazzle DVC 170 PAL Problem - 'mirrored' screen
By Glaucous in forum CapturingReplies: 0Last Post: 25th Sep 2007, 06:58
