Hello. I downloaded an 8.5 gig mkv with an aspect ratio that is just a tad bit skewed. Its an 16:9 but the image looks too squashed that way and looks much better at 4:3. So im wondering what app i should use for making minor changes like this? When i searched the forum it pointed me to a guide that was last updated in 2005 so i thought i should better ask instead. Any help is appreciated, thanks!![]()
Results 1 to 16 of 16
Thread: Changing aspect ratio on an mkv?
Thank you much Baldrick! I already have those apps but i didnt know you could do that with them.
Is there something that works on AVI's too?
mpeg4modifier. But not all players will read the aspect ratio in avi files.
Hi Baldrick,Originally Posted by Baldrick
What do you mean by your comment here ... could you put it in a dummy-proof lingo if possible!
Thanks,
G!
Sorry to keep bumping but is there something that works on WMV's too? There are just so many movies on the net with a bad ratio! Thanks so much.
Hi Vato,
Baldrick and couple of other folks here are the experts ... but if you have a WMV file ... my guess would be it is best to convert it 1st to an AVI ... then you can deal with it with the Tools are available here ...
One tool that Bladrick suggested to me and just recently used is "AVI Recomp 1.5.0" ... it walks you thru total reconverting of the file ... but it is timely ... which I have no Patience for that ...
Hope this was of some help ...
G!
VirtualDub + DirectShow plugin.
I have the plugin and ive gone thru the panel but i dont see where to change the ratio.Originally Posted by jagabo
Either use the Resize filter to change to a 4:3 frame size and use square pixel encoding, or leave the resolution intact and set 4:3 DAR in the output codec (assuming whatever codec you want to use supports DAR flags).
There's another possibility: if you can find a program that will remux from the WMV container to an MKV container you can use the MKV header to specify a display aspect ratio.
Any way to change a mov's aspect ratio? =)
Guys, i have a problem. I just downloaded an mkv thats set at 1440 1080 and mkvmerge is not fixing it. I set the display width at 1080x1920 and then i tried 1280x720 but the output always comes out at the source's settings. Am i doing something wrong? Please help.
yep ive got a couple mkv's that are 16:9 but play as 4:3 ive changed the header with mkvmerge but they still play as 4:3
ok mkvmerge has worked for me afterall. i was playing the wrong copy of the file after editing the header.
just changed DISPLAY HEIGHT in the header to what it should be and now the file plays correctly as 16:9
the correct answer is:
Code:mkvpropedit /video.mkv --edit track:1 --set display-height=x
Converting MKV for use in non-linear editor; also changing aspect ratio
By noctrine in forum Video ConversionReplies: 5Last Post: 9th Feb 2012, 10:49 -
Changing a DVD's Aspect Ratio
By soneman in forum Authoring (DVD)Replies: 11Last Post: 8th Sep 2009, 18:18 -
Changing aspect ratio.
By Lyceum in forum EditingReplies: 5Last Post: 28th May 2009, 12:19 -
Changing aspect ratio?
By Marlow in forum Video ConversionReplies: 2Last Post: 5th Apr 2009, 05:40 -
WMV Aspect Ratio Changing?
By Crazyj32 in forum Video ConversionReplies: 4Last Post: 5th Dec 2008, 21:55
