Hi,
Can you use the Hauppauge HD-PVR HD Video Recorder for normal television or does it have to be HD?
Thanks![]()
It accepts standard definition as composite or analog component. It has no tuner.
http://www.hauppauge.com/site/products/data_hdpvr.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
The Component input can be 480i, 480p, 720p or 1080i
Now as for High Definition or Standard Definition rec format it make no diff to the HD-PVR it all depend on your video output from your cable or satellite set top box which can be in 16:9 or 4:3 aspect ratio and display modes/resolutions 480i, 480p, 720p or 1080i.
Composite and S/Video can only do 480i
Do bear in mind that when recoding in 4:3 AR and with 480i Res and movie your rec in widescreen you end upscaling when using a WideScreen TV Monitor. To get around that problem and look rigth it best setup your cable or satellite set top box as 16:9 AR and with 480i or if have the option go for 480p Res.
Hauppauge HD PVR
By Susan_T in forum Video StreamingReplies: 1Last Post: 21st Nov 2011, 20:06 -
Hauppauge HD PVR capture and jerky video issue
By Split Infinity in forum CapturingReplies: 0Last Post: 10th Apr 2010, 07:27 -
Hauppauge HD PVR
By karebo in forum DVB / HDTVReplies: 13Last Post: 6th Jun 2009, 08:57 -
Fix H.264 video clip? (another hauppauge HD PVR)
By unplug in forum EditingReplies: 0Last Post: 1st Sep 2008, 23:39 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum CapturingReplies: 1Last Post: 11th Mar 2008, 09:04
Statistics
Newest guides
Latest tool updates
New media comments
