To what extent could I use this with these specs until I upgrade (which will be soon) -
Core 2 Duo 2.67GHz
2 GB RAM
8600GTS
Some random regular HDD 320GB
How will this do with the compressed codec or whatever? What about editing or rendering?
I plan on getting
4 GB RAM (total)
Not exactly sure what graphics card but it'll be good enough
Two 500GB HDD on RAID 0 - maybe two 1 TB HDD
Thread: My specs with an Intensity Pro
That should be enough for the MJPEG codec.Originally Posted by kILLDR3n
Editing depends on the software you intend to use and how you define "editing". Those specs meet Premiere Pro CS4 minimums. Rendering speed will scale with CPU power.
For uncompressed 720p capture you will need two drives in RAID 0 (not counting separate OS drive).Originally Posted by kILLDR3n
For uncompressed 1080i capture you will need three to four drives (960 Mb/s sustained) in RAID 0 (not counting separate OS drive). For 1080i be prepared for 422 GB per hour.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
If you haven't already purchased a BlackMagic Intensity Pro, send me a PM.
Looking to sell mine
Awful lot of questions about these cards lately.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
What is that data rate for MJPEG? I only have like 100 GB left on my HDD, but I'm going to upload my videos straight to youtube after I record and they're not something I necessarily need to back up so I'll probably delete them off the HDD.
If I were going to livestream with this card would I need any more than 2GB of RAM or better than my dual core 2.67GHz cpu?
Black Magic Intensity Shuttle or Intensity Pro?
By perasbro in forum CapturingReplies: 3Last Post: 12th Oct 2011, 17:56 -
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
Blackmagic Intensity Pro.
By liamb96 in forum CapturingReplies: 8Last Post: 18th Oct 2010, 16:20 -
Last try for intensity pro help
By predrawN in forum CapturingReplies: 3Last Post: 26th May 2010, 00:42 -
By Richintx in forum CapturingReplies: 0Last Post: 23rd Jan 2010, 09:43
