VideoHelp.com Forum
Results 1 to 10 of 10
    Many people on this forum say you need Raid setups for uncompressed capture with the BlackMagic Intensity. This may be true now but for how much longer? I have been doing some research on solid state drives, where some drives seem to have extremely impressive read and write speeds. There are already 1 TB solid state drives on the market - see:
    http://www.pcworld.com/article/18286...over_3000.html
    I know these are expensive now, however in time there price will rival that of normal drives. With these solid state dives is a Raid setup really necessary for uncompressed HDMI capture?
    SSD's aren't big enough, or at sane prices. Even 1TB is kind of puny for uncompressed.
    well 1 TB seems big enough
    Maybe if you're wanting just an hour or so of video. I forget the exact specs, but 1TB is puny.
    Yes 1TB is puny, but this technology can only improve and come down in cost. Think of the prices of 1TB normal drives 5 years ago, and compare today. Do you really think people won't be using Solid state drives in mass over the next 5 years?
    1 hour of 1920x1080 30 fps uncompressed YUY2 video is about 450 GB and requires at least 125 MByte/s sustained write thoughput.
    Originally Posted by marada
    this (SSD) technology can only improve and come down in cost
    Hard drives too.
  7. Member edDV's Avatar
    In other words, ITB will hold just over two hours of uncompressed 1080i.
    The "Colossus" solid state drives you referenced above claim 220 MB/s (1,760 Mb/s) sustained transfer which should be enough.
    http://www.ocztechnology.com/product...ata_ii_3_5-ssd
    SSD drives are known to "wear out" with erasure cycles so performance may degrade with use.
    http://www.kiva.org/about
    2 hours of uncompressed capture would seem ok, as you would only use the drive during capture, and then archive the footage somewhere else.
    I take the point about performance degrading with use, however from what I have read manufacturers are addressing this, and some even claim their drives are as reliable as conventional hard drives. I guess with conventional drives you have the added problem of moving parts etc. Also a Raid 0 setup is not the most reliable thing in the world. I have just had my setup die caused by a malfunctioning hard drive. Surely it is better to rely on one solid state drive for capture rather than use multiple conventional drives in a Raid, as statistically you have a much higher rate of failure.
  9. Member Cornucopia's Avatar
    If you're going to do HD with BMIntensity, and do it without major compromises, you'll need the space.
    The Colossus 1TB SSD mentioned above is ~$3500 with tax. For that amount of money, I could get 4TB!! of Raid 6+0 in a 4-way stripe (with Hotswap tower enclosure). This would have a ~>250MB/s sustained xfer vs. the SSD's 220, AND would have multiple drive hot-swappability (at least 2 drives would have to simultaneously go bad for there to be any loss at all ; great odds - it IS one of the most realiable on earth!). The SSD doesn't have any redundancy at all.
    For a particular job that must be done, and for a particular budget, it just makes more sense to use a proven current (and cheap) technology than to be wowed by sleek, tiny newer technology. (Thinking like an engineer, not a consumer)
    From what I've read, SSDs are nowhere near as reliable as claimed. Failure rate in the field is much higher than hard drives.
  1. Blackmagic Intensity Pro Question
    By wcwman18 in forum Media Center PC / MediaCenters
    Last Post: 22nd Jul 2011, 16:45
  2. Blackmagic Intensity Shuttle
    By mayhampixi in forum Capturing
    Last Post: 6th Jun 2011, 15:54
  3. Blackmagic Intensity Pro.
    By liamb96 in forum Capturing
    Last Post: 18th Oct 2010, 16:20
  4. BlackMagic Intensity?
    By StEaLtHsHoT in forum Capturing
    Last Post: 12th Dec 2009, 16:18
  5. Blackmagic Intensity Pro + Xbox 360 Hookup Question
    By xmadmardiganx in forum Capturing
    Last Post: 15th May 2009, 16:52
