I'm running WinXP with SP3
I have smplayer and Quicktime Pro 7.6.5
this .mov file won't play in either smplayer or Quicktime strangely enough.
I ran it in VLC player but it said it need some sort of "WMV3" codec. So I downloaded a windows media player codec pack
but that still failed. I don't see how a .mov file would need a Windows Media player codec![]()
View log> Mplayer:
C:/Program Files/SMPlayer/mplayer/mplayer.exe -noquiet -nofs -nomouseinput -sub-fuzziness 1 -identify -slave -vo directx -ao dsound -nokeepaspect -priority abovenormal -framedrop -nodr -double -wid 2229212 -colorkey 0x020202 -monitorpixelaspect 1 -ass -embeddedfonts -ass-line-spacing 0 -ass-font-scale 1 -ass-styles C:/Documents and Settings/D/.smplayer/styles.ass -fontconfig -font Arial -subfont-autoscale 0 -subfont-osd-scale 20 -subfont-text-scale 20 -subcp ISO-8859-1 -vid 1 -subpos 100 -volume 100 -cache 2000 -osdlevel -noslices -channels 2 -af scaletempo,equalizer=0:0:0:0:0:0:0:0:0:0 -softvol -softvol-max 110 C:/Documents and Settings/D/My Documents/arizonacharadesall 1.mov -loop 0
MPlayer Sherpya-SVN-r29355-4.5.0 (C) 2000-2009 MPlayer Team
Setting process priority: abovenormal
Playing C:/Documents and Settings/D/My Documents/arizonacharadesall 1.mov.
Cache fill: 0.00% (0 bytes)
libavformat file format detected.
ID_AUDIO_ID=0
[lavf] Audio stream found, -aid 0
ID_VIDEO_ID=1
[lavf] Video stream found, -vid 1
VIDEO: [WMV3] 320x240 24bpp 29.970 fps 0.0 kbps ( 0.0 kbyte/s)
Clip info:
title:
ID_CLIP_INFO_NAME0=title
ID_CLIP_INFO_VALUE0=
author: *removed*
ID_CLIP_INFO_NAME1=author
ID_CLIP_INFO_VALUE1=*removed*
copyright: *removed*
ID_CLIP_INFO_NAME2=copyright
ID_CLIP_INFO_VALUE2=*removed*
genre: Adults Only
ID_CLIP_INFO_NAME3=genre
ID_CLIP_INFO_VALUE3=Adults Only (lol)
ID_CLIP_INFO_N=4
ID_FILENAME=C:/Documents and Settings/D/My Documents/arizonacharadesall 1.mov
ID_DEMUXER=lavfpref
ID_VIDEO_FORMAT=WMV3
ID_VIDEO_BITRATE=0
ID_VIDEO_WIDTH=320
ID_VIDEO_HEIGHT=240
ID_VIDEO_FPS=29.970
ID_VIDEO_ASPECT=0.0000
ID_AUDIO_FORMAT=WMA2
ID_AUDIO_BITRATE=0
ID_AUDIO_RATE=44100
ID_AUDIO_NCH=2
ID_LENGTH=1737.10
ID_SEEKABLE=1
ID_CHAPTERS=0
[ass] auto-open
[ass] Init
[ass] Updating font cache.
Opening video decoder: [dmo] DMO video codecs
ERROR: Could not open required DirectShow codec wmv9dmod.dll.
DMO dll supports VO Optimizations 0 1
DMO dll might use previous sample when requested
IMediaObject ERROR: 00E4F4EF input format not accepted (0x80040205 : -2147220987)
Failed to create DMO filter
You need to upgrade/install the binary codecs package.
Go to http://www.mplayerhq.hu/dload.html
VDecoder init failed
ERROR: Could not open required DirectShow codec wmvdmod.dll.
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Could not open codec.
Cannot find codec 'wmv3_vdpau' in libavcodec...
Cannot find codec matching selected -vo and video format 0x33564D57.
Cannot find codec for audio format 0x32414D57.
Audio: no sound
Video: no video
Exiting... (End of file)
ID_EXIT=EOF
Results 1 to 9 of 9
Thread: .mov Will not play :(
More information on exactly how you obtained this file might be useful. I am assuming that you did not create it yourself and it may be of questionable legality. Possibilities include the fact that it is corrupted (if you got it from Bit Torrent this is much more likely than you realize), the file is DRM encumbered or simply was created improperly.
Based on some of the info above, I will make a guess that this is an, ahem, adult MOV file and it's got DRM. There is no way that I know of to remove QuickTime DRM. That's one of the reasons it gets used - it's one of the few DRM schemes that still work.
LOL ya, finally hit 18.Originally Posted by jman98
And also yup downloaded from hotfile from some random. What exactly is a DRM?
It's encrypted, see http://en.wikipedia.org/wiki/Digital_rights_management . You have to buy it to view it.
Baldrick is correct, but I don't recommend this. Adult websites are notorious for overcharging and refusing to stop charges. You'll have to pay by credit card. I've heard of people having to cancel credit cards as the only way to stop recurring charges from adult websites.Originally Posted by Baldrick
Why else do you think I download them via torrent and rapishare etc :POriginally Posted by jman98
but is there any way to decrypt them>?
I doubt this is an encryption issue but a fake file like others I warn people about
Note the kbyte/s
Some of these when played will direct you back to the website where you can subscribe and then watch the video
All you have done is downloaded a fake file with 0 video data
A very nice way of getting you to install malware also ... be cautious
Under normal circumstances it should be ... note the kbyte/s again
VIDEO: [WMV3] 1280x720 24bpp 100.000 fps 3000.0 kbps (366.2 kbyte/s)
I'm sure if it were malware my Ad-aware wouldve picked it up or even Malwarebytes would've picked it up.
So i doubt it is malware
And it doesnt direct me to anysites when i open it
It didnt actually start playing the video it just stopped. could that be why it said 0kbs?Under normal circumstances it should be ... note the kbyte/s again
Tried that and still didnt workOriginally Posted by email
How do i play these mov files?
By perfection in forum Software PlayingReplies: 3Last Post: 11th Sep 2010, 15:42 -
H.264 .mov files do not accurately play. Help!
By wonderkev in forum Video ConversionReplies: 22Last Post: 4th Feb 2010, 14:01 -
Play .mov files with FFDShow
By loekverhees in forum Newbie / General discussionsReplies: 13Last Post: 11th Sep 2009, 10:45 -
HD .mov file that won't play with anything (dvhp? what the hell is that?)
By Salva Veritate in forum Newbie / General discussionsReplies: 16Last Post: 13th Feb 2009, 17:05 -
help~ cant play my mov
By Kimgris in forum Software PlayingReplies: 1Last Post: 12th Jul 2008, 00:30
