VideoHelp.com Forum
  1. Member Hal05154's Avatar
    Hello,
    Just curious. I have a new Blu Ray player and Dish HD. Is there an affordable splitter cable or box so I can play both on my high def tv? Right now im plugn and unplugn.
    Thanks,
    Hal
    I'm afraid. I'm afraid, Dave. Dave, my mind is going. I can feel it..... Yup. Spppllttt. It's gone.
  2. Member fritzi93's Avatar
    You don't have any HDMI inputs on the HDTV?
    Pull! Bang! Darn!
  3. Mod Neophyte Super Moderator redwudz's Avatar
    I would look around at Monoprice: http://www.monoprice.com/home/index.asp Not sure what type of splitter you're looking for but it sounds like you need a switch instead.
  4. Member Hal05154's Avatar
    Fritzi93,
    Yes, I do, it's but there is only ONE and I TWO items to use it, hence my need for a splitter of some type.
    Redwudz does this make sense now to you?
    I have 2 HDMI players (DISH and a BluRay player). MY HDTV only has 1 HDMI input. Looking for some kind of plug in with a switch of some type that will allow me to have both plugged in at all times so don't have to switch between plugging the two in and out.
    THANKS!
    Hal
  5. Member Hal05154's Avatar
    Redwudz, you rock. I saw what I needed at that site. Yes, I was mistaken in my terminology. I wanted a switch. THANK YOU!
    Hal
  6. Mod Neophyte Super Moderator redwudz's Avatar
    I thought that might be it. I use a HDMI splitter to split my HDMI output from my HDMI switch to both my projector and my HDMI LCD monitor at the same time. I have a couple of Monoprice's HDMI switches and they have worked great for me. I use a 5 input one at present. Their cable prices are also very good.
  1. Replies: 3
    Last Post: 25th Feb 2012, 18:00
  2. Gabest MP4 splitter vs. Haali Media Splitter
    By jaduvil in forum Software Playing
    Last Post: 16th Jun 2010, 11:57
  3. Most affordable customizable computer site?
    By MikeMGMVE in forum Computer
    Last Post: 3rd Jul 2008, 10:18
  4. looking for a good affordable recorder
    By stiltman in forum DVD & Blu-ray Recorders
    Last Post: 4th Apr 2008, 15:01
  5. Looking to buy an affordable TV with Digital Tuner.
    By John Shumate in forum DVB / HDTV
    Last Post: 30th Nov 2007, 11:41
