Hi,
I know this question has been asked a million times. I have been reading all I can and nothing I have tried will work so I thought I would clean the slate and ask the pros to kindly explain what I need to do as simply as possible.
I am trying to convert some VHS recordings to DVD.
I have a cheap USB 2.0 TV Box that I am using(its all I can afford for right now).
It seems to do the job decently.
I am using the software that came with it InterVideo WINDVR 3 to record which makes a MPEG File.
The problem I have and would like to remove is a steady/consistent static(Fuzzy kind of sound) sound(its like that even when watching the tapes on regular TV).
So what would be the best way to remove this sound and then burn to DVD?
Also any simple ways to remove commercials? this isn't as important as cleaning up the sound though.
Any help would be greatly Appreciated
Thank You
LCE
Thread: VHS to DVD Cleanup?
Access the linear track in the VCR. Removing buzz after the fact can be pretty hard.
I've written about this before here:
http://www.digitalfaq.com/forum/show...atic-1163.html
using techniques found here:
http://www.digitalfaq.com/forum/foru...mprove-17.html
and some posts also here:
http://www.tvpreservation.com/forum/...o-tech-21.html
and to a lesser extent, in here somewhere, long ago:
http://forum.videohelp.com/restoration-f43.html
Again, best bet is a better VCR. That's the real issue.Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Thanks lordsmurf,
I'll check out the links you posted and do some more reading.
I have successfully been able to edit the audio but when I combine the audio/video I am know having issues with them being out of synch?
I Appreciate the help
VHS Cleanup, What can i do?
By Asesinato in forum RestorationReplies: 115Last Post: 5th Apr 2012, 12:31 -
VHS Cleanup, have i done enorgh?
By Asesinato in forum CapturingReplies: 24Last Post: 30th Mar 2012, 06:48 -
cleanup on old vhs tapes
By kesuki in forum Video ConversionReplies: 1Last Post: 22nd Jun 2008, 16:33 -
Anyone doing Straight D-VHS to H.264 Capture + Post Editing / Cleanup?
By bradeso in forum RestorationReplies: 4Last Post: 22nd Apr 2008, 03:01 -
Truly awful quality VHS - need hints for best cleanup software to =>dvd
By Wills in forum RestorationReplies: 13Last Post: 15th May 2007, 16:02
Statistics
Newest guides
Latest tool updates
New media comments
